Changed battery, recoded, will not start
Ok, I know I should look thru the threads, try to find the answer, but I honestly don't have the time. So, to start, my camshaft position sensor went out. While I was changing this, my younger brother, in his infinite wisdom, decided to unhook my battery. It was already weak, so I've replaced it. Re-coded with vag-com. Won't start. Tries to turn over, not for long, and doesn't start. I have many codes popping up, majority of them are open circuit, or lower limit voltage. Not really sure what is going on. I'm posting this on my phone, I'll try and get my codes posted to this thread tomorrow. But any help would be greatly appreciated. I'm stuck driving my 97 f-150. Really miss my car.
Recoding for battery won't affect basic starting. Battery just needs a good baseline charge. Thus honestly, my first guess is you still have...a bad battery. If it turns over but "not for long," that is basic battery oomph to me.
Recoding for battery won't affect basic starting. Honestly my first guess is you still have...a bad battery. If it turns over "but not for long," that is basic battery oomph to me. A8's fit any of the various size batteries listed for different years and motors, so I would also get the Big Boy as these get older.
I've been trying to get the codes to my phone without any luck. Here's a quick rundown the list. I'll show what's faulted.
01- engine, engine mount sol valve, open circuit
03- abs, control module defective
05- acc/start auth, 00179-00183, all show open circuit
08- HVAC, duration of ignition off time, defective
09- cent elec, cannot be reached
25- immobilizer, same as address 05
38- roof electronics, light detection, open or short to plus - a bunch of under voltage and over voltage
46- central conv, no signal from steering column, tail lights, alarm horn - supply voltage lower limit, footwell lighting, open or short to plus- comm wire to taillight malfunction
Alot of the same, either open or short to plus, or a lower limit exceeded.
And the battery meter in the mmi isn't showing 100% on a new battery, but it's around 75%. Wouldn't that be enough, my last battery always showed just a line above 50%, and I didn't have this problem until my brother unhooked the battery without a trickle charger connected to the car.
Let's be specific: what battery did you put in? Which Group? (one of the OE sizes hopefully...) New or used? Returnable? Also, when you charge, where exactly are you hooking the charger up? FWIW if you are doing the negative to the battery directly, it will further goof things up, including the display. Negative needs to go to the big hex post above the battery. Positive does go direct to battery; just be careful with the little (factory) wire that hooks to the positive terminal.
Saturday,21,October,2017,17:00:47:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUML44E44N000966 License Plate:
Mileage: 300150km-186504mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76 77
VIN: WAUML44E44N000966 Mileage: 300150km/186504miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 1010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0050
Revision: 00000000 Serial number: AUX3Z0C1511220
Coding: 0007773
Shop #: WSC 33229 067 57207
VCID: 1F4D05F7CE4807E68D9-804A
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0060
Coding: 0000002
Shop #: WSC 02353 785 00200
VCID: 24470A1BE72E243ED0B-8071
2 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
RPM: 1664 /min
RPM: 1760 /min
RPM: 2560 /min
(no units): 6.0
(no units): 42.0
Temperature: 62.0°C
T.B. Angle: 38.8°
Voltage: 13.04 V
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 -
Freeze Frame:
RPM: 1664 /min
RPM: 1760 /min
RPM: 2560 /min
(no units): 6.0
(no units): 42.0
Temperature: 62.0°C
T.B. Angle: 38.8°
Voltage: 13.04 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 55042 000 00000
VCID: 2149030FF83C3116BBD-8074
2 Faults Found:
00003 - Control Module
014 - Defective
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0C1511220
Coding: 0410624
Shop #: WSC 44049 001 1048576
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
6 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 21:20:00
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0050
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
VCID: 23450907E2202306A91-8076
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 38008 km
Time Indication: 0
Date: 2003.03.08
Time: 03:55:26
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 346BD037501109
Coding: 0000103
Shop #: WSC 08221 444 58652
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000065135
Subsystem 3 - Serial number: 0130.04.080000000100010171˙
Subsystem 4 - Serial number: 010171˙
3 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:24:04
02259 - Information Display and Control Head (Front) (J685)
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Mileage: 300152 km
Time Indication: 0
Date: 2017.10.11
Time: 18:20:08
Freeze Frame:
Bin. Bits: 0000001
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:07:22
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 959 772
Component: KLIMAAUTOMAT 015 0240
Revision: 00000013 Serial number: 00000000012689
Coding: 0037185
Shop #: WSC 02311 785 00200
VCID: DABBF4E315EA22CE3A7-808F
Subsystem 1 - Part No: 4E0 910 772
Component: Sitzluefter FS H05 010
Subsystem 2 - Part No: 4E0 910 772
Component: Sitzluefter BFS H05 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO10032003065A000000000095˙89
Subsystem 5 - Serial number: 000095˙898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO10032003065A00000000
Subsystem 7 - Serial number: 65A000000000015˙
4 Faults Found:
00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 51
Mileage: 295794 km
Time Indication: 0
Date: 2017.08.23
Time: 05:34:37
Freeze Frame:
Voltage: 13.10 V
(no units): 156.0
(no units): 0.0
00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 67
Mileage: 281582 km
Time Indication: 0
Date: 2017.04.06
Time: 10:15:40
Freeze Frame:
Voltage: 13.60 V
(no units): 205.0
(no units): 255.0
00730 - Potentiometer in Positioning Motor for Central Vent (G138)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 298501 km
Time Indication: 0
Date: 2017.09.23
Time: 05:52:25
Freeze Frame:
Voltage: 12.60 V
(no units): 93.0
(no units): 255.0
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 298501 km
Time Indication: 0
Date: 2017.09.23
Time: 05:52:25
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0011001
Shop #: WSC 55042 116 51756
VCID: 2A5BE423850AF24EEA7-807F
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 55042
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 299587 km
Time Indication: 0
Date: 2017.10.04
Time: 20:32:28
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 A
Component: Airbag 8.4E+ H08 0820
Coding: 0530707
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H09 0030
Coding: 0012241
VCID: E5C1D71F2C949D36875-80B0
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H42 0060
Revision: D07 Serial number: AUDID3C2000394
Coding: 0000223
Shop #: WSC 08221 444 83902
VCID: DCB7F2FB1FDEDCFE28B-8089
3 Faults Found:
00251 - Fuel Supply Sensor 4 (G393)
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 34
Mileage: 271652 km
Time Indication: 0
Date: 2016.08.25
Time: 11:01:24
00439 - Fuel Supply Sensor 3 (G237)
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 34
Mileage: 271652 km
Time Indication: 0
Date: 2016.08.25
Time: 10:24:40
Freeze Frame:
Fault Status: 00000011
Fault Priority: 4
Fault Frequency: 3
Reset counter: 28
Mileage: 271652 km
Time Indication: 0
Date: 2003.02.28
Time: 19:22:40
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H06 0040
Revision: 06 Serial number: 50003222014301
Coding: FCFE7BDD2B3304
Shop #: WSC 33933 111 123456
VCID: 264310139112D62ECEF-8073
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 28
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:14:43
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Reset counter: 28
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:16:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 299587 km
Time Indication: 0
Date: 2017.10.04
Time: 20:32:28
00465 - Control Module for Telephone/Telematic (J526)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 300049 km
Time Indication: 0
Date: 2017.10.10
Time: 18:38:28
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111
Component: CD-Changer H43 0430
Serial number: AUZ5ZBC1011965
Shop #: WSC 00000 000 00000
VCID: 1B3531E7DA501BC6611-804E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 21:20:00
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 C HW: 4E0 907 553 C
Component: LUFTFDR.-CDC H04 4190
Coding: 0015500
Shop #: WSC 40332 444 14896
8 Faults Found:
00776 - Level Control System Sensor; Left Front (G78)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 20
Reset counter: 68
Mileage: 0 km
Time Indication: 0
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 171
Reset counter: 255
Mileage: 286719 km
Time Indication: 0
Date: 2017.05.30
Time: 18:11:46
00139 - Left Front Body Acceleration Sensor (G341)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 288157 km
Time Indication: 0
Date: 2017.06.12
Time: 05:29:17
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 288157 km
Time Indication: 0
Date: 2017.06.12
Time: 05:29:17
01316 - ABS Control Module
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2017.10.11
Time: 17:53:31
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 68
Mileage: 300152 km
Time Indication: 0
Date: 2003.02.27
Time: 00:01:23
01598 - Drive Battery Voltage
Freeze Frame:
Fault Status: 11100010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 21:34:31
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:05:44
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071534
4 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 0 km
Time Indication: 0
Date: 2004.01.01
Time: 00:00:00
02003 - Driver Identification Control Module (J589)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 28
Mileage: 8172 km
Time Indication: 0
Date: 2016.06.16
Time: 01:29:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 38008 km
Time Indication: 0
Date: 2012.04.17
Time: 03:55:22
01915 - Lumbar Support Height Adjustment Sensor (G374)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 28
Mileage: 248880 km
Time Indication: 0
Date: 2012.04.08
Time: 01:27:19
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H41 1100
Revision: 00000000 Serial number: 355DM037503771
VCID: 387FCE6B4BA650DE6C3-806D
3 Faults Found:
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
02445 - Disk Drive Initialization Error
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:15:38
Freeze Frame:
Hex Value: 0x592B
Hex Value: 0x13CA
Hex Value: 0x5379
Hex Value: 0x0000
02927 - DVD Read Error
Freeze Frame:
Fault Priority: 6
Fault Frequency: 255
Reset counter: 68
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:14:39
Freeze Frame:
Hex Value: 0x3E6A
Hex Value: 0x69AC
Hex Value: 0x0A01
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0070
Serial number: 00000304100240
Coding: 0003989
VCID: 1D313FFFC44415F69F5-8048
2 Faults Found:
02104 - Light Detection Sensor (G399)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 28
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 28
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM004 0080
Coding: 0028196
VCID: DEB3F8F309C2CEEE46F-808B
2 Faults Found:
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:14
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040303240130
Coding: 0065054
VCID: 275D1D179618CF26F59-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 62
Mileage: 299587 km
Time Indication: 0
Date: 2017.10.04
Time: 20:32:33
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 3
Reset counter: 28
Mileage: 283475 km
Time Indication: 0
Date: 2017.04.24
Time: 05:55:43
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Reset counter: 28
Mileage: 207088 km
Time Indication: 0
Date: 2009.08.10
Time: 15:28:48
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000011401
Coding: 0010111
VCID: DDB1FFFF04C4D5F65F5-8088
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T01J3E
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 62
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 28
Mileage: 262136 km
Time Indication: 0
Date: 2017.10.11
Time: 18:24:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 262136 km
Time Indication: 0
Date: 2017.10.01
Time: 16:40:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM004 0080
Coding: 0028196
3 Faults Found:
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:44
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:44
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
VCID: 204F060BF336381EB43-8075
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:37
Freeze Frame:
Voltage: 7.25 V
Count: 200
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2CBCC033DBAEA0E627-80B7
5 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 27
Mileage: 287464 km
Time Indication: 0
Date: 2017.06.04
Time: 11:17:35
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 287464 km
Time Indication: 0
Date: 2017.06.04
Time: 11:17:36
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 21:44:57
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 21:45:19
00070 - Starting Battery Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 22:07:21
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0480
Revision: 00000000 Serial number: 304C9037520514
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:23
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 29
Mileage: 298501 km
Time Indication: 0
Date: 2017.09.23
Time: 00:30:45
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0160
Revision: 00000000 Serial number: 00000000002597
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 03910061KN
Coding: 303030393135313035414B56413030333931303036314B4E
Shop #: WSC 09504 444 84390
5 Faults Found:
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 182
Reset counter: 255
Mileage: 264528 km
Time Indication: 0
Date: 2003.03.06
Time: 22:17:40
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 159
Reset counter: 255
Mileage: 250650 km
Time Indication: 0
Date: 2015.02.15
Time: 18:07:05
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 216
Reset counter: 255
Mileage: 250668 km
Time Indication: 0
Date: 2015.02.16
Time: 07:05:02
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Reset counter: 255
Mileage: 281613 km
Time Indication: 0
Date: 2017.04.06
Time: 17:12:46
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 28
Mileage: 271652 km
Time Indication: 0
Date: 2003.02.28
Time: 19:23:40
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028196
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Address 65: Tire Pressure
Cannot be reached
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0080
Coding: 0028196
3 Faults Found:
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 299712 km
Time Indication: 0
Date: 2017.10.06
Time: 17:37:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Address 75: Telematics
Cannot be reached
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001208
VCID: E0CFC60B33B6F81E743-80B5
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:10:42
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:40
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
Saturday,25,November,2017,16:35:50:62939
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Sporadic communication error 1000
Coding: 0007773
1 Fault Found:
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Coding: 0000002
Coding: 0007597
1 Fault Found:
014 - Defective
Coding: 0410624
Subsystem 1 - Part No: 4E0 905 852 B
Component: ELV 1734
5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
Coding: 3940576
Coding: 0000103
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:51:49
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Coding: 0037185
1 Fault Found:
014 - Defective
Coding: 0011001
Coding: 00000030
Shop #: WSC 55042
2 Faults Found:
02601 - Drivers Side Footwell Light (W9)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.29
Time: 20:14:56
02602 - Passenger Side Footwell Light (W10)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.29
Time: 20:14:56
Coding: 0530707
Coding: 0012241
Coding: 0000223
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:32:45
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:34:12
Coding: 0410624
Component: ELV 1734
4E0905852B ELV 1734
5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
Coding: 0015500
1 Fault Found:
Freeze Frame:
Fault Status: 11101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:51:08
Coding: 4071534
3 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 0 km
Time Indication: 0
Date: 2004.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 28
Mileage: 8172 km
Time Indication: 0
Date: 2016.06.16
Time: 01:29:59
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 28
Mileage: 248880 km
Time Indication: 0
Date: 2012.04.08
Time: 01:27:19
4 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 4
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.10
Time: 23:01:31
Freeze Frame:
Hex Value: 0x3E98
Hex Value: 0x964B
Hex Value: 0x0600
Hex Value: 0x1472
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 0
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:34:22
Freeze Frame:
Hex Value: 0x3E80
Hex Value: 0xED51
Hex Value: 0x3C78
Hex Value: 0x0000
03183 - Data Media not Compatible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.10
Time: 23:01:43
Freeze Frame:
Hex Value: 0x3E98
Hex Value: 0x9659
Hex Value: 0x0000
Hex Value: 0x9494
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:33:22
Freeze Frame:
Hex Value: 0x3E80
Hex Value: 0xED8B
Hex Value: 0x0A01
Hex Value: 0x0000
Cannot be reached
Coding: 0028196
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:14
Coding: 0001024
7 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 62
Mileage: 299587 km
Time Indication: 0
Date: 2017.10.04
Time: 20:32:33
Freeze Frame:
Fault Priority: 3
Reset counter: 28
Mileage: 283475 km
Time Indication: 0
Date: 2017.04.24
Time: 05:55:43
Freeze Frame:
Fault Priority: 3
Reset counter: 68
Mileage: 207088 km
Time Indication: 0
Date: 2009.08.10
Time: 15:28:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:14:25
01696 - Footwell Lighting; Rear Left (W45)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 13
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:37:58
01697 - Footwell Lighting; Rear Right (W46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:37:59
02200 - Communication Wire to Taillights
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:47:50
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 M HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0450
Revision: Dev_D01U Serial number: 00000000168890
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:13:26
Coding: 0010111
5 Faults Found:
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.08
Time: 22:11:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 62
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 68
Mileage: 262136 km
Time Indication: 0
Date: 2017.10.11
Time: 18:24:00
Freeze Frame:
Fault Status: 00110100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 262136 km
Time Indication: 0
Date: 2017.10.01
Time: 16:40:00
Coding: 0028196
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Revision: --H03---
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 68
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:37
Freeze Frame:
Voltage: 7.25 V
Count: 200
Coding: 0000001
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 27
Mileage: 287464 km
Time Indication: 0
Date: 2017.06.04
Time: 11:17:35
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 287464 km
Time Indication: 0
Date: 2017.06.04
Time: 11:17:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 21:44:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 21:45:19
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 1048568 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:23
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 29
Mileage: 298501 km
Time Indication: 0
Date: 2017.09.23
Time: 00:30:45
Subsystem 1 - Part No: 000 915 105 AC
Component: von VA0 03910061DF
Coding: 303030393135313035414356413030333931303036314446
2 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.26
Time: 00:12:27
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.26
Time: 00:14:27
Coding: 0028196
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Cannot be reached
Coding: 0028196
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 299712 km
Time Indication: 0
Date: 2017.10.06
Time: 17:37:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 B
Component: Telematik USA1 0080
Revision: 00000004 Serial number: 0000ATD3013911
Coding: 0000005
VCID: E0CFC60B30B6F81E743-5072
3 Faults Found:
01531 - Emergency Battery
02084 - Component Protection
Coding: 0001208
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:10:42
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:40
Cannot be reached
Coding: 0007773
Coding: 0000002
2 Faults Found:
18265 - Load Signal
Freeze Frame:
RPM: 1664 /min
RPM: 1760 /min
RPM: 2560 /min
(no units): 6.0
(no units): 42.0
Temperature: 62.0°C
T.B. Angle: 38.8°
Voltage: 13.04 V
P1847 - 000 -
Freeze Frame:
RPM: 1664 /min
RPM: 1760 /min
RPM: 2560 /min
(no units): 6.0
(no units): 42.0
Temperature: 62.0°C
T.B. Angle: 38.8°
Voltage: 13.04 V
Coding: 0007597
2 Faults Found:
014 - Defective
Coding: 0410624
Component: ELV XXXX
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 21:20:00
Coding: 3940576
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 38008 km
Time Indication: 0
Date: 2003.03.08
Time: 03:55:26
Coding: 0000103
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:24:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Mileage: 300152 km
Time Indication: 0
Date: 2017.10.11
Time: 18:20:08
Freeze Frame:
Bin. Bits: 0000001
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:07:22
Coding: 0037185
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 51
Mileage: 295794 km
Time Indication: 0
Date: 2017.08.23
Time: 05:34:37
Freeze Frame:
Voltage: 13.10 V
(no units): 156.0
(no units): 0.0
Freeze Frame:
Fault Priority: 3
Reset counter: 67
Mileage: 281582 km
Time Indication: 0
Date: 2017.04.06
Time: 10:15:40
Freeze Frame:
Voltage: 13.60 V
(no units): 205.0
(no units): 255.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 298501 km
Time Indication: 0
Date: 2017.09.23
Time: 05:52:25
Freeze Frame:
Voltage: 12.60 V
(no units): 93.0
(no units): 255.0
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 298501 km
Time Indication: 0
Date: 2017.09.23
Time: 05:52:25
Coding: 0011001
Coding: 00000030
Shop #: WSC 55042
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 299587 km
Time Indication: 0
Date: 2017.10.04
Time: 20:32:28
Coding: 0530707
1 Fault Found:
Coding: 0012241
Coding: 0000223
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 34
Mileage: 271652 km
Time Indication: 0
Date: 2016.08.25
Time: 11:01:24
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 34
Mileage: 271652 km
Time Indication: 0
Date: 2016.08.25
Time: 10:24:40
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 28
Mileage: 271652 km
Time Indication: 0
Date: 2003.02.28
Time: 19:22:40
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 28
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:14:43
Freeze Frame:
Fault Priority: 3
Reset counter: 28
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:16:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 299587 km
Time Indication: 0
Date: 2017.10.04
Time: 20:32:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 300049 km
Time Indication: 0
Date: 2017.10.10
Time: 18:38:28
Coding: 0410624
Component: ELV XXXX
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 13
Mileage: 286560 km
Time Indication: 0
Date: 2017.05.28
Time: 19:28:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 21:20:00
Coding: 0015500
8 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 20
Reset counter: 68
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Reset counter: 255
Mileage: 286719 km
Time Indication: 0
Date: 2017.05.30
Time: 18:11:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 288157 km
Time Indication: 0
Date: 2017.06.12
Time: 05:29:17
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 288157 km
Time Indication: 0
Date: 2017.06.12
Time: 05:29:17
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2017.10.11
Time: 17:53:31
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 68
Mileage: 300152 km
Time Indication: 0
Date: 2003.02.27
Time: 00:01:23
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 21:34:31
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:05:44
Coding: 4071534
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 0 km
Time Indication: 0
Date: 2004.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 28
Mileage: 8172 km
Time Indication: 0
Date: 2016.06.16
Time: 01:29:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 38008 km
Time Indication: 0
Date: 2012.04.17
Time: 03:55:22
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 28
Mileage: 248880 km
Time Indication: 0
Date: 2012.04.08
Time: 01:27:19
3 Faults Found:
Freeze Frame:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:15:38
Freeze Frame:
Hex Value: 0x592B
Hex Value: 0x13CA
Hex Value: 0x5379
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 6
Reset counter: 68
Mileage: 286574 km
Time Indication: 0
Date: 2017.05.28
Time: 18:14:39
Freeze Frame:
Hex Value: 0x3E6A
Hex Value: 0x69AC
Hex Value: 0x0A01
Hex Value: 0x0000
Coding: 0003989
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 28
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 28
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:00
Coding: 0028196
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:14
Coding: 0065054
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 62
Mileage: 299587 km
Time Indication: 0
Date: 2017.10.04
Time: 20:32:33
Freeze Frame:
Fault Priority: 3
Reset counter: 28
Mileage: 283475 km
Time Indication: 0
Date: 2017.04.24
Time: 05:55:43
Freeze Frame:
Fault Priority: 3
Reset counter: 28
Mileage: 207088 km
Time Indication: 0
Date: 2009.08.10
Time: 15:28:48
Cannot be reached
Coding: 0010111
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 62
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 28
Mileage: 262136 km
Time Indication: 0
Date: 2017.10.11
Time: 18:24:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 262136 km
Time Indication: 0
Date: 2017.10.01
Time: 16:40:00
Coding: 0028196
3 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:44
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:44
Revision: --H03---
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:37
Freeze Frame:
Voltage: 7.25 V
Count: 200
Coding: 0000001
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 27
Mileage: 287464 km
Time Indication: 0
Date: 2017.06.04
Time: 11:17:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 287464 km
Time Indication: 0
Date: 2017.06.04
Time: 11:17:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 21:44:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 21:45:19
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 22:07:21
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:23
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 29
Mileage: 298501 km
Time Indication: 0
Date: 2017.09.23
Time: 00:30:45
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 264528 km
Time Indication: 0
Date: 2003.03.06
Time: 22:17:40
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 250650 km
Time Indication: 0
Date: 2015.02.15
Time: 18:07:05
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 250668 km
Time Indication: 0
Date: 2015.02.16
Time: 07:05:02
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Reset counter: 255
Mileage: 281613 km
Time Indication: 0
Date: 2017.04.06
Time: 17:12:46
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 28
Mileage: 271652 km
Time Indication: 0
Date: 2003.02.28
Time: 19:23:40
Coding: 0028196
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Cannot be reached
Coding: 0028196
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 299712 km
Time Indication: 0
Date: 2017.10.06
Time: 17:37:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Cannot be reached
Coding: 0001208
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:10:42
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:40
Cannot be reached
Coding: 0007773
1 Fault Found:
Coding: 0000002
Coding: 0007597
1 Fault Found:
014 - Defective
Coding: 0410624
Component: ELV 1734
5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
Coding: 3940576
Coding: 0000103
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:51:49
Coding: 0037185
1 Fault Found:
014 - Defective
Coding: 0011001
Coding: 00000030
Shop #: WSC 55042
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.29
Time: 20:14:56
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.29
Time: 20:14:56
Coding: 0530707
Coding: 0012241
Coding: 0000223
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:32:45
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:34:12
Coding: 0410624
Component: ELV 1734
4E0905852B ELV 1734
5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 28
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:45:24
Coding: 0015500
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:51:08
Coding: 4071534
3 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 0 km
Time Indication: 0
Date: 2004.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 28
Mileage: 8172 km
Time Indication: 0
Date: 2016.06.16
Time: 01:29:59
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 28
Mileage: 248880 km
Time Indication: 0
Date: 2012.04.08
Time: 01:27:19
4 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.10
Time: 23:01:31
Freeze Frame:
Hex Value: 0x3E98
Hex Value: 0x964B
Hex Value: 0x0600
Hex Value: 0x1472
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 0
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:34:22
Freeze Frame:
Hex Value: 0x3E80
Hex Value: 0xED51
Hex Value: 0x3C78
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.10
Time: 23:01:43
Freeze Frame:
Hex Value: 0x3E98
Hex Value: 0x9659
Hex Value: 0x0000
Hex Value: 0x9494
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:33:22
Freeze Frame:
Hex Value: 0x3E80
Hex Value: 0xED8B
Hex Value: 0x0A01
Hex Value: 0x0000
Cannot be reached
Coding: 0028196
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:14
Coding: 0001024
7 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 62
Mileage: 299587 km
Time Indication: 0
Date: 2017.10.04
Time: 20:32:33
Freeze Frame:
Fault Priority: 3
Reset counter: 28
Mileage: 283475 km
Time Indication: 0
Date: 2017.04.24
Time: 05:55:43
Freeze Frame:
Fault Priority: 3
Reset counter: 68
Mileage: 207088 km
Time Indication: 0
Date: 2009.08.10
Time: 15:28:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:14:25
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:37:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:37:59
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 28
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:47:50
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:13:26
Coding: 0010111
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.08
Time: 22:11:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 62
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 68
Mileage: 262136 km
Time Indication: 0
Date: 2017.10.11
Time: 18:24:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 262136 km
Time Indication: 0
Date: 2017.10.01
Time: 16:40:00
Coding: 0028196
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Revision: --H03---
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 68
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:37
Freeze Frame:
Voltage: 7.25 V
Count: 200
Coding: 0000001
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 27
Mileage: 287464 km
Time Indication: 0
Date: 2017.06.04
Time: 11:17:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 287464 km
Time Indication: 0
Date: 2017.06.04
Time: 11:17:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 21:44:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 300152 km
Time Indication: 0
Date: 2003.03.08
Time: 21:45:19
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 1048568 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:23
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 29
Mileage: 298501 km
Time Indication: 0
Date: 2017.09.23
Time: 00:30:45
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.26
Time: 00:12:27
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.26
Time: 00:14:27
Coding: 0028196
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Cannot be reached
Coding: 0028196
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 299712 km
Time Indication: 0
Date: 2017.10.06
Time: 17:37:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 68
Mileage: 300144 km
Time Indication: 0
Date: 2003.03.08
Time: 22:09:12
Coding: 0000005
3 Faults Found:
Coding: 0001208
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:10:42
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 300153 km
Time Indication: 0
Date: 2003.03.08
Time: 22:08:40
Cannot be reached
I've put a brand new battery in. It's a class 49 battery, stock size. 1100 ca, 950 cca. Strongest I could find. MMI reads full 100%. Tried to start with no luck. Turns over just fine, but no start. Sprayed some ether in the air box, still nada. Vag com is saying open short to both cam pos sensors. I have searched through a lot of the different post's, and when I changed out the battery, I let it sit unhooked for about an hour. The other things I've read, was to touch the cables together, and lose all charge from the car. Question on that, does it harm anything. Just at a loss. Really hoping that the timing isn't off. That sounds expensive. I don't have a manual for it yet and am not sure on location of a fuse that might be the culprit. Any guidance would be greatly appreciated.
Hello Segur,
In both full scans that you posted, neither of them show any fault for "cam pos sensors", in fact your first scan shows no engine faults at all, and your second scan only show a faulty engine mount (very common), what I do see is trouble with Address 05: Acc/Start Auth, maybe you should go back and clear all faults one by one and then do a new scan and post it, and I mean clear each address fault one by one, not the "clear all faults" button.
