Component Protection Error
I have had this error, never recieved until a couple of months ago. Was told that I must have changed a module to get this error. I have not change any modules. I could have done something else in the VAG to get this, although I do not remember. Any ideas why this would come up without a module being changed.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 346JX037507394
Coding: 0000003
Shop #: WSC 00066 210 01865
VCID: 2F6A8B93BE0EEB46F4-807A
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 390IL057503251
Subsystem 3 - Serial number: 7402.09.0500000000290B0053ÿ
Subsystem 4 - Serial number: 0B0053ÿ
1 Fault Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 31
Mileage: 192244 km
Time Indication: 0
Date: 2003.06.18
Time: 00:00:10
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 31
Mileage: 192244 km
Time Indication: 0
Date: 2003.06.18
Time: 00:00:10
Have you cleared this to see what comes back? If I believe what it says, apparently you got the fault only once, and nominally it was back in 2003??
If it is recurring, do you have AMI retrofit by chance (or anything else)? Maybe something in the check the box type configuration stuff isn't matched up to the modules the car sees electronically. But more generally, if it works, I just let it go. Like my sporadic passenger door latch button type code when it still seems to work.
