Sponsored by:
Sponsored by:
Convenience open/close with remote?
Old 05-14-2009, 10:23 PM
awdinut's Avatar
Default Convenience open/close with remote?
Is it possible to Vag Com that feature into a D3 like I did with my D2? How?
Old 05-15-2009, 12:34 PM
Junior Member
PsYcHe UK's Avatar
You mean to hold down the open button and have the windows open?
If so, it's in the MMI setttings (car/setup IIRC). It may be turned off, it's definitely an option in my UK 2003 (US 2004) D3.
May need VAG-COM to turn it on if the US have decided on some strange spec change i suppose.
Old 05-16-2009, 06:05 PM
awdinut's Avatar
Its not in the"CAR SET UP" menu in the US. It was not offered by Audi on the D2 but some one figured out a way to VagCom a code that would enable the function. I have been told there is a way to program the D3 with the VAgCom to enable the function , but no one knows where to find a write up to get the necessary values.
Old 05-16-2009, 08:40 PM
MP4.2+6.0's Avatar
Default Just as I mentioned to you on the other board a week or two ago
openobd.org. Please check it. All the document codes are there for this and other things too.
Control module adaptation
Select 46 (Comfort System)Adaptation -> Function 10
-> Channel 61 (Comfot Functions)
+001 - Comfort closing for window regulators via remote control
+002 - Comfort opening for window regulators via remote control
+004 - Comfort closing for sunroof via remote control
+008 - Comfort opening for sunroof via remote control
+016 - Comfort closing for window regulator via switch drivers door
+032 - Comfort opening for window regulator via switch drivers door
+064 - Comfort locking for sunroof via switch drivers door
+128 - Comfort opening for sunroof via switch drivers door
+256 - Comfort closing for window regulators via lock cylinder
+512 - Comfort closing for sunroof via lock cylinder
Old 05-16-2009, 08:50 PM
MP4.2+6.0's Avatar
Default Here in the VAG-COM wiki too as I also mentioned in the other post...
http://wiki.ross-tech.com/index.php/..._System#Coding
Old 05-17-2009, 05:54 AM
awdinut's Avatar
Thankyou for posting that source for me! I had tried all the other sites you had suggested, but I don't remember seeing that one. The D3 can has more convenience options than the D3 did...the D2 would not open the sunroof with the remote.
And while I am at it, I'll say "THANKYOU" to you for all the other posting you do to answer questions for all of us!! You seem to be the most prolific poster on this D3 forum...without your obviously advanced knowledge of these cars this forum would leave a lot of questions(read problems) unanswered.
Old 05-27-2009, 12:30 PM
JLM04A8L's Avatar
Did you figure this out? My '04 has 34 as the current value for channel 61...I tried adding the numbers and entered 39 for the additional features I want (locking windows and sunroof only)..could not get it to work with the remote and reset the code back to 34. I was afraid I might mess something up.
Old 06-02-2009, 07:24 AM
JLM04A8L's Avatar
The issue was I did not enable the comfort option in the coding: 0000064 = Comfort Function via Remote active...works great now. Also figured out vag com lowering needs to be done through the coding as well..changing the values alone will not lower the car.
Old 06-09-2009, 04:16 PM
Mister Bally's Avatar
Did it and it works great!
A slightly more detailed procedure for others: as listed in the earlier post: go to controller 46> Adaptation>function 10 Channel 61. Enter the number of your desired bells & whistles you want to activate. I enabled all of them so the number is 1023. Save, close controller.
Then, same controller (46) but go to > Coding 07 > My original setting was 65054. I added the 64 which enables the remote control (key fob) "Do It/save"
Close controller.
All done and good to go!
Old 06-10-2009, 03:53 AM
Close controller.
To clarify; New setting is 65118 in this section (coding 07)
Quick Reply: Convenience open/close with remote?
