coolant bleed valve locations?
#11
Puddle underneath reservoir may be bad reservoir rather than any overheat. Over time we have had posts of both cracked reservoirs and leaking sensors at bottom of reservoir. Sensor is molded into the overall reservoir so not a separate part. But if it has low coolant from that draining down to sensor level, that should throw a dash warning and also kick in the jet engine fan protective mode.
Balsapal (05-07-2022)
#12
So, I did some further testing this afternoon. I opened the bleed valves (underneath cabin filter), gradually filled reservior to let out any air pockets, closed both and then ran heat on HI to get the juices flowing again. I noticed the fans were still going at full/high speed. (Ps: the spill yesterday was from the overflow line in the expansion thank - due to coolant level rising in the tank.) I confirmed that this afternoon.
Out of curiosity, I decided on another approach- take some readings off measuring blocks.
![Name: IMG_20160731_191411_zps6tyklyqs.jpg
Size: 269.8 KB](https://www.audiworld.com/forums/attachments/a8-s8-d3-platform-discussion-60/72653d1501255591-coolant-bleed-valve-locations-img_20160731_191411_zps6tyklyqs.jpg)
Most of the readings seem logical (given the fans were at full blast) but I don't get the -48 degrees C reading from 'Temperature diagnosis'. That seems out of range...perhaps a faulty temperature sensor? I had this same reading from a C5 years ago, and the ECT had to be replaced.
Ps: Strange that VCDS Autoscan is not reporting a faulty sensor; what am I missing?
#13
![](http://i1115.photobucket.com/albums/k551/de0412/D3%20A8/IMG_20160731_191411_zps6tyklyqs.jpg)
#14
#15
Hello ebi718,
You say "Most of the readings seem logical (given the fans were at full blast)"
Yet your fans only show 52 and 58 percent, is that considered full blast ?
#16
Thanks; will schedule this weekend.
I am not sure if that's full blast....do you know? Please share if you do.
MuRaN0Daddy
10-03-2005 09:48 PM
audipride87
Audi 100 / A6 (C4 Platform)
09-10-2005 10:56 AM
Crisqo09 T.O.
04-30-2003 07:26 AM
