Coolant Tank Cracked
Dumb question, but does anyone know if you can epoxy the coolant tank?? (Just wondering if the epoxy may react with the fluid)
I found a crack in the outlet pipe where the hose clamps onto it and no dealer in Aust. has a tank...
Thanks
Thanks
http://jbweld.net/products/uses.php
Don't know if you can find a similar product down there though.
I've used this stuff with fair results on an Audi coolant expansion tank. It lasted a few months.
I believe we can get JB here.
Cheers
Well, i'm not the one to ask. It would be JB Weld people that would be able to give a proper answer.... My guess is that since it is a expansion tank, it actually gets ever so slightly larger when hot and back to original size when the engine is cold....... Thermal expansion of the tank (versus the glue or whatever the JB Weld compound is) is probably different. Eventually, the JB Weld starts to separate from the expansion tank and the coolant leaks out again. At least this will allow you some time to order a new tank from Audi or whoever you choose to buy your parts from.
Of course, as you mentioned in your original post, there is the chance that the coolant itsellf breaks down the adhesive and causes it to separate from the tank as well.
Audi dealers used to have a repair kit for expansion tank failures at the hose connection points where a milded pipe nipple would break off. It included a brass nipple and something very similar if not truly JB Weld. Even that repair kit did not last all that long for me and I had to buy the correct tank. Although maybe I'm thinking of where small air purge hose between the expansion tank connects to the radiator and the kit was for the radiator. This was on my '87 5000CS quattro (probably known as a 200Q down under.....
The shop I bought it off also mentioned about the sleeve solution, but couldn't find one to suit my car.
Cheers
I had my coolant tank get a crack near the top lid. Dealer diagnosed it as a leaking radiator... So much they know. After a long diagnosis, replaced the tank and all is well. Might be better off just replacing after how much it expands and contracts under heat and cold. Part isn't too expensive, but if the crack is small enough just mend it.
Drove 200km today and all held up fine, so we'll see how she goes. It due for a service in about 2 weeks so I suspect that who ever works on it will break the bottle then no matter how uch I stress to be careful with it.
Yeah, agree with you. Prob is, Audi Aust don't have the bottle and if they did, it would cost about $500. And to order it, would take 10 weeks... Man I hate living here when it comes to parts.
