Cost of replacing oil cooler
#21
Does anyone have any news on the maybe way to do this with out pulling the engine. Had the coolant leak since the beginning of winter but its been on and off. drive around with coolant in the trunk. i also bought the replacement pipe .
#23
I purchased the Bufkin pipe. Hope never need it. Never used the Bar Stop Leak either. Used to add a little water pump lube back when antifreeze was not "lifetime" service interval.
Using it seems like my way of fixing an issue, not yours. The method shown in the pictures looks tough.
#24
I red that o-ring is leaking, though I saw a picture of a broken plastic pipe too, but I believe it was broken in the process. I thought that if it is only o-ring some "liquid aluminum" should seal it and it did right away. Compared to taking apart half of a car, lower half ... ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I love her, but I love myself too.![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Edit: I have aluminum pipe with four o-rings. Just in case.
#28
Hi I'm trying to remove those exhaust studs to move coolant pipe up to clear oil cooler. I'm not having any luck. I tried to lock two nuts together and then remove them with a deep well but they don't loxk together the just spin off together. What am I doing wrong? Thanks in advance
#29
