"Crunch" or squeak from front suspension
#11
Well this is interesting... did some poking around... and my sound is coming from the left front fender!! With the car in the garage, and obviously totally still, if I just push on the fender behind and below where it meets the headlight, it makes the sound I'm hearing.
Now, I absolutely HATE dealing with anything bodywork related, so anyone have any ideas what's making contact that I'm hearing this?
#12
could someone post the picture where we are suppose to lubricate it??
i have the same problem.. granted it is -11F outside with
wind chills of -30F![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
but would still like to get rid of the "crunchy" noise
wind chills of -30F
#13
Took my car in to the dealer yesterday. I had a brake flush done a couple months ago there and recently since the weather got colder my brake lights would turn on overnight on their own and drained the battery. I suspected air still in the lines so took it back.
I also had a few concerns about some noise in the front end, mostly on the front left (Drivers Side) exactly as you guys said, heard a rubber crunching sound. Got the call today turns out Bad Control Arm Bushings and Sway Bar Bushings. As well as the front struts being blown.
So definitely get it checked out if you hear the crunching sound. I had heard some noise back in October and took it in for a checkup but Dealer said they didn't see anything wrong. 3 Months later all those Bushings need to be replaced.
#16
Broken bushings could be easily overlooked in the early stage. Three months and cold weather could make a difference.
Front struts wise I would definitely look for second and third opinion. Each one is $1500 plus labor and you didn't mention any symptoms.
#17
Forgot to say the car was lowering itself pretty low on the front end over night.
When I would go out to turn the car on in the morning my front tires were tucking in the front fenders. Car would lift up right away as I got into the car but this was every morning.
Good thing, dealer called me to let me know my extended warranty only needed me to call in and confirm the repairs. All is being covered. I'll have her back next Wednesday.
For now enjoying driving the new Supercharged A6. Quick little sucker.
#18
You forgot to say two minor things: that your front end is bottoming overnight and that you have warranty. From what you didn't forget to say I was under impression that you need some help.
#20
F@kk!!! Spoke too soon.
Now getting push back from the warranty, not wanting to cover the air struts even though they are covered and are faulty.
Audi Dealer told me they confirmed no leaks in the lines and Valve Block, compressor is also working fine too.
The warranty adjuster says he needs proof from the dealership that the air struts are leaking. I don't know what else to do now. Dealer says they showed the adjuster the air lines, compressor and valve block holding pressure, but the adjuster/warranty wants more they want to see the leak from the struts. Audi says the air bags are enclosed and they can't simply spray water on it to show the leak. wTF!!!
Anyone ever go through this!?
