D.I.Y. Timing Belt Replacement
#41
I went into my profile but it won't let me edit my profile. Is there a way to go about doing this?
Edit:
Is this the correct Serpentine belt Idler? Audi D3 A8 Quattro 4.2 - 079903341F - Accessory Belt Idler Pulley - ES#285142
#42
Hi, I'm a super newbie and I just bought a 2007 A8L and there is nothing in my manual about changing the timing belt. At how many miles is this done? This looks like an incredibly massive undertaking!
#43
If you are in the U.S, you won't have a timing belt in 2007. You will have the timing chain. Congratulations on your purchase!
#44
2007 (and on) doesn't have timing belt. Camshafts are driven by chains. No maintenance required.
#45
Thank you for an excellent writeup.
I'm in this process, but I'm daunted by the amount of special tools I have to buy, I thought I could get away with just the camshaft holding tool, but now I fear I have to order more tools and spend more $$$. :/
#46
You can rent them as well. Shoot me a PM with an email address if you want to discuss renting them from me.
Since you already started the job, looks like you need them pretty quick. I will not be able to ship them out until next week due to travel. That said, I'd need a deposit sent anyway. I will try to check my PM's in case you want to discuss. Leave a phone number in a PM for a faster reply.
#47
http://www.ebay.com/itm/VW-Audi-V6-V8-Camshaft-Cam-Sprocket-Engine-Timing-Tool-Puller-T40001-/251449100139?hash=item3a8b88c76b&item=251449100139&vxp=mtr
#48
#49
I would like to thank you for your write up it was excellent details by details great job. Well I just bought a 2004 a8l and P0020 and p0492 codes were scaned when I purchase it, p0020 is camshaft position actuator circuit open bank 2, any idea witch side it is and how to replace it? And p0492 is secondary air injection system insuficient flow bank 2, I think this second code was activated due to the first one any ideas......the car drives perfect no issues accelerating starting etc,,, I can't register the car here in ct until I clear the chk engine light.can you help
#50
for the SAI check the plumbings.....
