Dash Board control module fault code
The scan shows fault code 00003 on the dash board control module faulty static. The dash board functions normal but i can not clear the code . I have tried pulling out the fuse for a few minutes but still the same any advise please
Read this ?
00003 - Ross-Tech Wiki
Or this one more helpful.
Instrument Cluster fault code [Archive] - VW Audi Forum - The #1 VW Group Community
Have been playing around with any of the coding ?
Could you paste the error code printout ?
![](https://cimg7.ibsrv.net/gimg/www.audiworld.com-vbulletin/720x1280/screenshot_2016_04_01_17_24_19_1ed9f07243b56618a8d3f969a028e6ef7ff2937a.png)
Read this ?
I haven't been playing with the coding.
3 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF) ( 3 in the 403 coding)
2003 does not support this I think
4 = Great Britain ?( 4 in the 403 coding )
That's about all I can see
I think its the needle sweep. could be wrong.
Coding
Coding
- ????xxx: Options
- +0016 = Tire Pressure Monitoring System (MY 2005+)
- +0032 = Advanced Frontlightning System (MY 2006+)
- xxxx?xx: Country
- 0 = Germany
- 1 = Rest of World (Left-Hand-Drive)
- 2 = USA
- 3 = Canada
- 4 = Great Britain
- 5 = Japan (Left-Hand-Drive)
- 6 = Arabian States
- 7 = Australia
- 8 = Rest of World (Right-Hand-Drive)
- 9 = Japan (Right-Hand-Drive)
- xxxxx?x: Seatbelt Warning (3-6 = MY 2005+ only)
- 0 = No Seatbelt Warning
- 1 = Seatbelt Warning (EU-NCAP)
- 2 = Seatbelt Warning (NAR Old)
- 3 = Seatbelt Warning (NAR New)
- 4 = Seatbelt Warning (EU-NCAP incl. Passenger)
- 5 = Seatbelt warning (NAR Old incl. Passenger)
- 6 = Seatbelt Warning (NAR New incl. Passenger)
- xxxxxx?: Illumination I (without Parking Light LED)
- 0 = Needles OFF and Scales OFF (Term. 15 ON / Term. 58 OFF)
- 1 = Needles ON and Scales OFF (Term. 15 ON / Term. 58 OFF)
- 2 = Needles OFF and Scales ON (Term. 15 ON / Term. 58 OFF)
- 3 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF)
- 4 = Needle ON and Scales ON (Term. 15 OFF / Term. 58 OFF)
- xxxxxx?: Illumination II (with Parking Light LED | MY 2005 only)
- 5 = Needles OFF and Scales OFF (Term. 15 ON / Term. 58 OFF)
- 6 = Needles ON and Scales OFF (Term. 15 ON / Term. 58 OFF)
- 7 = Needles OFF and Scales ON (Term. 15 ON / Term. 58 OFF)
- 8 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF)
- 9 = Needles ON and Scales ON (Term. 15 OFF / Term. 58 OFF)
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 E
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D1020976
Coding: 0001743
Shop #: WSC 51670 000 104856
VCID: DCBCA31A1FFC11F89DD
No fault code found.
this is mine also has 3 on the end so must not be that.
Coding: 0001743
some of the guru's should be up soon they probably know.
have not played around with this before,
if its not affecting anything and you cannot fix it from info you get from here.
next time you get something done at audi get them to have a look at it.
The coding looks ok, but without a complete scan can't say 100% because we cant see what other modules are on the car.
the last digit relates to what part of the cluster lights up on different situations like ignition on, engine running etc
I would recommend you try to get a proper scan done as the generic code readers don't play very nicely with vag diagnostics.
Date: 2016-04-01 21:07
VIN: WAUZZZ4E83N005992
Car: Audi A8
Year: 2003
00 Steering Angle Sender
01 Engine Control Module 1
System description: 4.2L V8/5V G
Software version: 0040
Hardware number: 4E0910560E
Serial number: AUX3Z0C0307726
Coding: 0011773
Trouble codes:
P1876 - Valve for torque support mount Open circuit No signal/communication
static
02 Transmission Control Module
System description: AG6 09E 4,2L5V RdW
Software version: 0100
Hardware number: 4E0910156
Coding: 0000001
Trouble codes:
No trouble codes found
03 Brakes 1
System description: ESP 5.7 allrad H29
Software version: 0420
Hardware number: 4E0910517A
Coding: 0008597
Trouble codes:
00003 - Control module Faulty
static
05 Kessy
System description: FBS AUDID3 H12
Software version: 0200
Hardware number: 4E0910131
Coding: 0411648
Subsystems:
System description: ELV
Software number: 4E0905852B
Software version: 1734
Trouble codes:
06 Seat Adjustment Passenger Side
System description: Sitzmemory BFS H05
Software version: 0020
Hardware number: 4E0910760B
Serial number: 5DS 008 795-02
Coding: 4063232
Trouble codes:
07 Display Control Unit
System description: Interfacebox H43
Software version: 5570
Hardware number: 4E0910769Q
Serial number: 300A7037514812
Coding: 0000002
Subsystems:
System description: Bedienteil MMI H41
Software number: 4E0910609
Software version: 0010
Trouble codes:
08 Air Conditioning
System description: KLIMAAUTOMAT 011
Software version: 0190
Hardware number: 4E0910043
Serial number: 00000000009544
Coding: 0086129
Trouble codes:
00604 - Potentiometer - positioning motor for air flow flap Open circuit/short circuit to B+
Intermittent
09 Central Electrics
System description: ILM Fahrer H11
Software version: 0070
Hardware number: 4E0910279A
Coding: 0010001
Subsystems:
System description: Wischer WWS D3 H30
Software number: 4E2910113
Software version: 0310
Coding: 0000029
Trouble codes:
0F Radio Tuner - Digital
System description: DAB-Tuner H41
Software version: 0830
Hardware number: 4E0910563C
Serial number: KE1229T8000866
Coding: 0000001
Trouble codes:
15 Airbag
System description: Airbag 8.4E+ H08
Software version: 0840
Hardware number: 4E0910655
Coding: 0431707
Trouble codes:
16 Steering Column Electronics
System description: Lenksäulenmodul H08
Hardware number: 4E0910549
Coding: 0112141
Subsystems:
System description: Lenkradmodul H02
Software number: XXXXXXXXXXX
Software version: 0050
Trouble codes:
17 Dash Board
System description: KOMBIINSTR. VDO H40
Hardware number: 4E0910900
Serial number: AUDID3C0001320
Coding: 0000403
Trouble codes:
static
19 Gateway
System description: Gateway H06
Hardware number: 4E0910468
Serial number: 00003031090431
Long coding: FCFF7FDC2B7D04
Trouble codes:
1D Driver Identification
System description: FPI_1 H05
Software version: 0060
Hardware number: 4E0910218
Serial number: 11032004113510
Trouble codes:
1E Media Player Position 2
System description: CD-Changer H43
Software version: 0470
Hardware number: 4E0910111F
Serial number: AUZ5ZBB1007141
Trouble codes:
25 Immobilizer
Coding: 0411648
Subsystems:
Trouble codes:
28 Climate Control Unit Rear
System description: KLIMA-STG. FOND 011
Software version: 0160
Hardware number: 4E0910158
Serial number: 00000000003890!
Coding: 0000000
Trouble codes:
34 Ride Control System
System description: LUFTFDR.-CDC H03
Software version: 4190
Hardware number: 4E0910553C
Coding: 0015500
Trouble codes:
36 Seat Adjustment Driver Side
System description: Sitzmemory FS H05
Coding: 4063246
Trouble codes:
37 Navigation
System description: MNS ECE H41
Software version: 1060
Hardware number: 4E0910888P
Serial number: 305LN027518323
Trouble codes:
38 Roof Electronic Control Module
System description: Dachknoten D3 H01
Hardware number: 4E0910135A
Serial number: 00000234400076ÿ
Coding: 0035921
Trouble codes:
42 Door Electronics Driver Side
System description: Türsteuer.FS BRM004
Software version: 0080
Hardware number: 4E1910802
Coding: 0026914
Trouble codes:
46 Central Module Comfort System
System description: Komfortgeraet H02
Hardware number: 4E0910289
Coding: 0000761
Subsystems:
System description: Heckdeckel P27H08
Software number: 4E0910853
Software version: 0090
System description: Neigungssensor H01
Software number: 4E0907719
Trouble codes:
01134 - Alarm horn No signal/communication
static
47 Sound System
System description: DSP-Amp.-High H12
Software version: 0460
Hardware number: 4E0910223P
Serial number: 00000000066856
Coding: 0000027
Trouble codes:
02084 - Component protection no or incorrect basic setting/adaptation
static
4F Central Electrics 2
System description: ILM Beifahrer H06
Hardware number: 4E0910280
Serial number: 00000000007942
Coding: 0010101
Trouble codes:
52 Door Electronics Passenger Side
System description: Türsteuer.BF BRM004
Coding: 0026914
Trouble codes:
02126 - Central locking button, exterior door handle Implausible signal
static
53 Parking Brake
System description: EPB AV1C1010 H01
Software version: 1010
Hardware number: 4E0910801A
Serial number: RGB-BNO19.12.0
Coding: 0000531
Trouble codes:
55 Headlight Regulation
System description: Pre-AFS H01
Software version: 0030
Hardware number: 4E0910357
Coding: 0000002
Trouble codes:
56 Radio
System description: TUNER EU/US/RDW H41
Software version: 0630
Hardware number: 4E0910541T
Serial number: 304A9037515431
Coding: 0000001
Trouble codes:
00856 - Antenna, on radio Open circuit
static
00858 - Connection ZF output radio to antenna amplifier Open circuit
static
57 TV Tuner
System description: TV analog TUNER H14
Software version: 0300
Hardware number: 4E0910146G
Serial number: 00000000006031
Coding: 0000003
Trouble codes:
61 Battery Regulation
System description: ENERGIEMANAGER H02
Software version: 0240
Hardware number: 4E0910181B
Serial number: 00000002490388
Subsystems:
System description: von MLA 100119JZXI
Software number: 000915105AK
Long coding: 303030393135313035414B4D4C413130303131394A5A5849
Trouble codes:
62 Door Electronics Rear Left
System description: Türsteuer.HL BRM004
Hardware number: 4E0910802
Coding: 0026914
Trouble codes:
67 Voice Control
System description: SDS 3502 UK H42
Hardware number: 4E0910754S
Serial number: 00000212050007
Trouble codes:
72 Door Electronics Rear Right
System description: Türsteuer.HR BRM004
Coding: 0026914
Trouble codes:
76 Parking Assistance
System description: Parkhilfe 8-Kan H12
Hardware number: 4E0910283D
Serial number: 11001317500160
Coding: 0201008
Trouble codes:
77 Telephone
System description: TELEFONMODUL EU
Software version: 0770
Hardware number: 4E0910333F
Serial number: T2AUD31011H955
Coding: 0000004
Trouble codes:
this is the full scan. I use OBD eleven as I don't have ross tech cable
