Diagnostic code question
I'm getting codes P1128 and P1130 (bank 1 too lean and Bank 2 too lean) using Ross Tech interface and software. This is on my 2004 with 4.2L engine. The Berntley manual skips codes between P700 and P2000 so I have no clue where to look for the cause. Car runs perfect but the CEL is annoying. Anyone have a better list of codes?
Thanks in advance.
Thanks in advance.
This WIKI from Ross-Tech is in the range you are asking about:
http://wiki.ross-tech.com/wiki/index...P1640%2F005696
P1130: http://wiki.ross-tech.com/wiki/index.php/17538/P1130
Add'l info: http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info
Bentley has an online list, but no additional info: http://www.bentleypublishers.com/tec....dtc.table.htm
Massive amounts of measuring block and diagnostics info:
http://www.audi-portal.com/en/diagnostic/ecu.html
-Jake
-Jake
when I see lean codes, my instincts from my C5 4.2 are to look at the vacuum lines for leaks. If you have never replaced vacuum hose and have the braided cover junk (a constant as you know on VW's and Audi's), my practice is just to replace it all and save the repeated leaks. Tends to give out after 3-4 years where heat soaked (top and back of motor), and a bit more gradually in other areas.
If not in the vacuum lines, look more at the air injection pump--both the plumbing and the motor.
Branimir Podnar
06-09-2014 10:05 AM
PaulW
10
11-19-2008 06:42 AM
JohnnyBravoa4
VAG-COM Discussion
01-12-2007 06:20 AM
Anand@4Induktion.com
01-19-2001 10:39 PM
