Sponsored by:
Sponsored by:
Disabling TPMS
Old 05-13-2017, 10:10 AM
  #31
90SQ's Avatar
Originally Posted by 05SilverA8
I previously posted the VCDS settings to turn off TPMS here it is again:
If pulling the fuse works for you then go for it, my error did not go away. The proper way to do it is as follows, as I had posted before:
I was so tired of mine showing up on the dash, I tried the fuse routine and that did NOT work. I disabled the unit in the gateway, and re-coded the TPMS (65) to 0202125, which DISABLES the TPMS. Start car, no TPMS nag. If I would have known to change the sensors when I changed the tires I would have done that at the time (exactly 5 years of age on sensors). The Tire Rack has new sensors that are about $89 each.
Just done on my 08 S8 since i dont use TPMS in the summer time, worked great. In my 04 A8L i could turn the TPMS system off with the MMI, no coded required.
Thanks!!!
Old 05-13-2017, 11:36 AM
  #32
Tstealth32's Avatar
Just did all 5 tires. Sensors were still good, but coming up on the 10 year mark, so i changed them. Shows temp and pressure.
EON IM-3106 433 MHz TPMS Tire Pressure Sensors for Audi
upstateTT
09-06-2003 02:00 PM
A8CT
05-29-2003 11:24 PM
MuTTs
03-14-2002 10:56 PM
SmokeyA4turbod@ebay
11-20-2001 05:27 AM
Quick Reply: Disabling TPMS
