Sponsored by:
Sponsored by:
Driver door soft close
Old 01-18-2011, 04:22 AM
FischerWausau's Avatar
Default Driver door soft close
Doesn't work anymore and there is a noise when closing manually. Any ideas on easy fix?? Probably have to remove door panel- is that difficult?? Thx
Old 01-18-2011, 11:12 AM
Hilden's Avatar
Default Door panel removal
Check out the PDF. Behind the panel is a metal frame. I don't know how that one sits though but search the forum and I guess you'll find out.
File Type: pdf
Old 01-18-2011, 02:57 PM
awdinut's Avatar
Default Hilden:
I have sent you a PM
Old 01-19-2011, 09:35 AM
Hilden's Avatar
Will send you a pic. Too bad though I didn't know about that 2weeks ago when I had everything torn down and I could've given you much better details
Old 01-20-2011, 03:26 PM
Edd W's Avatar
Thread hi-jack - How do you add control of the Webasto aux heater to the MMI?
Old 01-21-2011, 09:38 AM
Hilden's Avatar
Hook up VCDS. Check that module 18 - aux heater is activated. Then go to module 08 auto HVAC, click Coding 07 and add 2 to the existing coding. Save, exit, ignition off and when you turn it on again you should see the timer menu under ACC setup menu.
Old 02-20-2011, 02:27 PM
Edd W's Avatar
Did it today - works fine thanks.
Old 04-15-2011, 11:52 AM
perlfather's Avatar
Default driver door soft close
Our car developed the same problem (stopped soft close and slight noise). From the sound I am guessing that some mechanical hook came undone, however, I have never seen this and have no idea what to do. I am contemplating taking the door panel off and having a look. Any conclusions from your work or any suggestions?
Old 04-15-2011, 02:28 PM
JP19640_0's Avatar
I'm have having the same problem with my drivers door
Old 04-16-2011, 05:50 PM
JP19640_0's Avatar
anyone have anymore info on this?
Quick Reply: Driver door soft close
