Engine Databus Error 6.0 W12
Good afternoon,
could you please help me with the following error ? I cannot seems to find any issues with the car ? What can cause such an issue and what is wrong ? The car was scanned with Ross Tech Hex V2. I have tried to find similar article but without success.
Address 01: Engine Labels: 07C-910-018-BHT1.lbl
Part No SW: 4E1 910 018 L HW: 4E0 906 018 C
Component: 6.0L W12/4V A ª0040
Revision: --H10--- Serial number: AUX3Z0GN336825
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 290FFF03C5F30FDFE93-807C
1 Fault Found:
18318 - Engine Databus
P1910 - 004 - Missing Message from Engine Control Module 2 - Intermittent
Readiness: 0000 0000
Thank you very much for the help in advance.
Jim
Coding: 0011773
1 Fault Found:
Jim
Welcome. Not sure, but for starters use Ross Tech (also known as VCDS or VAGCOM) to go into the OTHER engine module and clear any codes there. It is an oddity of both the S8 and W12 that the car actually has two separate engine computers. You have to read and sometimes clear codes in both. If problem persists after that, report back.
Hi,
thank you for the fast reply, yes i did use VCDS Ross Tech Hex V2. Tried to clear the errors and then scanned the car again the same message is still present. Should i go into the second engine module ? What should i be looking for ?
Thanks.
Thanks.
Just checked both modules from the manual menu selection and found out that the Readiness button is greyed out on the second engine module, but present and active on the first one ? What does it means ?
Thanks
Thanks
When you clear codes, it won't read "ready" for a couple of cold-hot-cold driving cycles, including some light highway miles along the way There are specific parameters, but that is the informal summary of what should work. Then either it will end up reading ready (there are 8 separate bits to what it is checking for readiness, though some are inactive test wise), or it will trigger an error and probably a check engine light. Thus, next step is to drive a few days and see what happens. Recheck after you are sure you have driven it a few times as outlined. Hopefully it then reads ready and no codes pop up in either engine module.
a4shon
VAG-COM Discussion
11-17-2006 10:00 AM
red90q
09-03-2006 01:09 PM
Bryce
01-04-2002 09:13 PM
