Engine Light, MisFire, Oil in 1 Coil Pack Tube
2007 A8L 4.2 135K
Engine light came on last week, mis-fire on cylinder 8. Had been running slightly rough, but not bad, then engine MIL went out. Bought 8 new coil packs and plugs, switched out. Noticed oil in 2nd cylinder from front passenger side on coil and plug when pulled. Cleaned up, started. Wouldn't stay running. Extremely rough, pulled back out. Found company sent me plugs for W12 vs. 4.2.
Got new/correct plugs, put back together. Started. Extremely rough - way worse than with old coils and plugs. Heavy oil on same Nothing else changed. Not sure where to start after running scan, clearing codes, going for a short ride and rescanning to below. Lots going on - First thoughts were valve cover gasket for passenger side, lots of low-intermittent power errors so new Battery??? Before tackling wanted any thoughts from the Audi experts on where to start. Thanks in advance
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUMV44E67N026161 Mileage: 218410km-135713miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: 71H21--- Serial number: AUX3Z0G6727516
Coding: 01060009190F0120
Shop #: WSC 02313 785 00200
VCID: 204FD7A7F36C863E5E-8074
4 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 180481 km
Time Indication: 0
Date: 2015.03.26
Time: 16:08:30
Freeze Frame:
RPM: 1060 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 21.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 11.176 V
008569 - Bank 2; System Too Lean off Idle
P2179 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 211410 km
Time Indication: 0
Date: 2016.02.28
Time: 18:24:41
Freeze Frame:
RPM: 1468 /min
Load: 39.6 %
Speed: 25.0 km/h
Temperature: 103.0°C
Temperature: 34.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.716 V
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 217660 km
Time Indication: 0
Date: 2016.05.01
Time: 07:04:37
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 20.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 9.779 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 217906 km
Time Indication: 0
Date: 2016.05.03
Time: 07:04:46
Freeze Frame:
RPM: 1263 /min
Load: 45.1 %
Speed: 0.0 km/h
Temperature: 15.0°C
Temperature: 15.0°C
Voltage: 11.176 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0030
Revision: --H01--- Serial number: 4354156
Coding: 0000002
Shop #: WSC 02313 758 00200
VCID: 2345D8ABE27A9D2643-8076
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224BDDAFFD60942E48-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0G6727516
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BFBF47EBBC0EFE66-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
VCID: 2447DBB7E7749A1E3A-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348GU077525262
Coding: 0000003
VCID: 336528EB529A0DA6B3-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000043291
Subsystem 3 - Serial number: 0124.07.070000000100010070ÿ
Subsystem 4 - Serial number: 010070ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000128459
Coding: 0037185
VCID: 1C37E357DF04A2DE82-8048
1 Fault Found:
00657 - Positioning Motor for Central Vents (V102)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 115
Reset counter: 202
Mileage: 212264 km
Time Indication: 0
Date: 2016.03.07
Time: 18:19:37
Freeze Frame:
Voltage: 14.40 V
Temperature: 16.0°C
(no units): 67.0
(no units): 69.0
Temperature: 15.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0143123
VCID: 366311FF41E8188E94-8062
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
5 Faults Found:
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 218410 km
Time Indication: 0
Date: 2016.05.06
Time: 17:15:48
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 218415 km
Time Indication: 0
Date: 2016.05.06
Time: 17:47:30
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 218410 km
Time Indication: 0
Date: 2016.05.06
Time: 17:15:50
00908 - Control Module for Wiper Motor
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 170
Mileage: 216735 km
Time Indication: 0
Date: 2016.04.23
Time: 07:12:28
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 218410 km
Time Indication: 0
Date: 2016.05.06
Time: 17:15:50
Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785
Component: SG ext.Player H09 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 2B55308B4AAA5566FB-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0114966
VCID: 2C5733978FA4525EF2-8078
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H14 4230
Revision: 91H14423 Serial number: 0037Q0G03LWM
Coding: 0532707
VCID: 2643C1BF9148680E24-8072
Subsystem 1 - Part No: 4E0 910 339 C
Component: BF-Gewichtsens. H02 0040
Subsystem 2 - Serial number: 00X7F
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ63
Subsystem 4 - Serial number: 000000ÿ63328RB402B82CB1Pÿ63
Subsystem 5 - Serial number: 82CB1Pÿ63428RB402B7FC8D4ÿ63
Subsystem 6 - Serial number: 7FC8D4ÿ63528RB402B82C2EVÿ63
Subsystem 7 - Serial number: 82C2EVÿ63628RB402B7FC04Wÿ63
Subsystem 8 - Serial number: 7FC04Wÿ63729RB402915CDD ÿ63
Subsystem 9 - Serial number: 15CDD ÿ63829RB402915D03Hÿ
Subsystem 10 - Serial number: 15D03Hÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H03000 Serial number: 90026071720059
Coding: 0012241
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0530
Revision: D05 Serial number: AUDID3G6004283
Coding: 0048263
Shop #: WSC 01123 444 82775
VCID: 2541C6B3EC4E63162D-8070
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B077058080
Coding: F5D5DF7F707A0E
VCID: 6CD7F3974F24925EB2-8038
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046006 Serial number: AUZ5ZBG3453304
VCID: 1A3BE54FD530DCEE90-804E
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Mileage: 218415 km
Time Indication: 0
Date: 2016.05.06
Time: 17:46:55
Freeze Frame:
Text: 00000000
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285FCF879B5C7E7E16-807C
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 218416 km
Time Indication: 0
Date: 2016.05.06
Time: 17:48:09
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 D HW: 4E0 919 887 M
Component: MNS US H49 0970
Revision: 00000000 Serial number: 381GW077523980
Shop #: WSC 01013 444 82775
VCID: 2F6D249BBEB22946D7-807A
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000716400036
Coding: 0003477
VCID: 1D31EE53C41EABD675-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
2 Faults Found:
02111 - Motor for Window Regulator
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 8
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:33:62
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:33:62
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040707180028
Coding: 0048702
VCID: 2A5B358F85504C6E00-807E
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
2 Faults Found:
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 183
Reset counter: 167
Mileage: 212325 km
Time Indication: 0
Date: 2016.03.08
Time: 07:05:21
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 216
Reset counter: 167
Mileage: 211096 km
Time Indication: 0
Date: 2016.02.26
Time: 17:12:35
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000009866
Coding: 0000016
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Mileage: 218415 km
Time Indication: 0
Date: 2016.05.06
Time: 17:46:06
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000122627
Coding: 0010111
VCID: 1E33E95FC918B0CE6C-804A
1 Fault Found:
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 218412 km
Time Indication: 0
Date: 2016.05.06
Time: 17:46:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:31:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:31:28
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000922
Shop #: WSC 13731 002 1048576
2 Faults Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 81
Mileage: 174968 km
Time Indication: 0
Date: 2015.01.09
Time: 00:01:37
Freeze Frame:
Voltage: 13.56 V
Count: 61
02438 - Left Parking Brake Motor Hall Sensor
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11110100
Fault Priority: 4
Fault Frequency: 45
Reset counter: 2
Mileage: 174968 km
Time Indication: 0
Date: 2015.01.09
Time: 00:01:37
Freeze Frame:
Voltage: 13.56 V
Count: 94
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 2959CA838056477609-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304BK047580924
Coding: 0000002
Shop #: WSC 08166 444 57519
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 218418 km
Time Indication: 0
Date: 2016.05.06
Time: 17:54:01
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000009845
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2707260729
Coding: 344530393135313035412056413032373037323630373239
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:38:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:38:28
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900052531
Coding: 0202125
3 Faults Found:
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 196
Mileage: 217660 km
Time Indication: 0
Date: 2016.05.01
Time: 07:06:10
Freeze Frame:
(no units): 0.0
Voltage: 2.30 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 253
Reset counter: 167
Mileage: 180481 km
Time Indication: 0
Date: 2015.03.26
Time: 16:12:01
Freeze Frame:
(no units): 0.0
Temperature: 3.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 33
Reset counter: 62
Mileage: 183707 km
Time Indication: 0
Date: 2015.05.04
Time: 10:25:54
Freeze Frame:
(no units): 35.0
Temperature: 18.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000707110090
Shop #: WSC 12336 024 394758
VCID: 34672BF757940A9EAA-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J77101R
Coding: 1120403
VCID: 5CB7A3579F84E2DE42-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:41:24
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:41:24
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730720812677
Coding: 0221208
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 HW: 4E0 862 335
Component: Handyvorb2 H10 0080
Revision: 00000000 Serial number: 00000007504867
Coding: 0010900
Shop #: WSC 02335 785 00200
VCID: 60CF97A7B3ECC63E1E-8034
End-------------------------(Elapsed Time: 03:23)--------------------------
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 180481 km
Time Indication: 0
Date: 2015.03.26
Time: 16:08:30
Freeze Frame:
RPM: 1060 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 21.0°C
Voltage: 11.176 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 211410 km
Time Indication: 0
Date: 2016.02.28
Time: 18:24:41
Freeze Frame:
RPM: 1468 /min
Load: 39.6 %
Speed: 25.0 km/h
Temperature: 34.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 217660 km
Time Indication: 0
Date: 2016.05.01
Time: 07:04:37
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 20.0°C
Voltage: 9.779 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 217906 km
Time Indication: 0
Date: 2016.05.03
Time: 07:04:46
Freeze Frame:
RPM: 1263 /min
Load: 45.1 %
Speed: 0.0 km/h
Temperature: 15.0°C
Temperature: 15.0°C
Voltage: 11.176 V
Coding: 0000002
Coding: 0007597
Coding: 0410624
Component: ELV XXXX
Coding: 4071520
Coding: 0000003
Coding: 0037185
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 202
Mileage: 212264 km
Time Indication: 0
Date: 2016.03.07
Time: 18:19:37
Freeze Frame:
Voltage: 14.40 V
Temperature: 16.0°C
(no units): 67.0
(no units): 69.0
Temperature: 15.0°C
Coding: 0143123
Coding: 00000034
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 218410 km
Time Indication: 0
Date: 2016.05.06
Time: 17:15:48
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 218415 km
Time Indication: 0
Date: 2016.05.06
Time: 17:47:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 218410 km
Time Indication: 0
Date: 2016.05.06
Time: 17:15:50
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 170
Mileage: 216735 km
Time Indication: 0
Date: 2016.04.23
Time: 07:12:28
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 218410 km
Time Indication: 0
Date: 2016.05.06
Time: 17:15:50
Revision: 00000000
Coding: 010000
Coding: 0532707
Coding: 0012241
Coding: 0048263
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Mileage: 218415 km
Time Indication: 0
Date: 2016.05.06
Time: 17:46:55
Freeze Frame:
Text: 00000000
Coding: 0015510
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 218416 km
Time Indication: 0
Date: 2016.05.06
Time: 17:48:09
Coding: 4071530
Coding: 0003477
Coding: 0032364
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:33:62
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:33:62
Coding: 0048702
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 167
Mileage: 212325 km
Time Indication: 0
Date: 2016.03.08
Time: 07:05:21
Freeze Frame:
Fault Priority: 3
Reset counter: 167
Mileage: 211096 km
Time Indication: 0
Date: 2016.02.26
Time: 17:12:35
Coding: 0000016
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Mileage: 218415 km
Time Indication: 0
Date: 2016.05.06
Time: 17:46:06
Coding: 0010111
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 218412 km
Time Indication: 0
Date: 2016.05.06
Time: 17:46:00
Coding: 0032364
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:31:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:31:28
Revision: AV1C1010
Coding: 0000922
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 81
Mileage: 174968 km
Time Indication: 0
Date: 2015.01.09
Time: 00:01:37
Freeze Frame:
Voltage: 13.56 V
Count: 61
Freeze Frame:
Fault Priority: 4
Fault Frequency: 45
Reset counter: 2
Mileage: 174968 km
Time Indication: 0
Date: 2015.01.09
Time: 00:01:37
Freeze Frame:
Voltage: 13.56 V
Count: 94
Coding: 0000018
Coding: 0000002
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 218418 km
Time Indication: 0
Date: 2016.05.06
Time: 17:54:01
Coding: 0032364
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:38:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:38:28
Coding: 0202125
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 196
Mileage: 217660 km
Time Indication: 0
Date: 2016.05.01
Time: 07:06:10
Freeze Frame:
(no units): 0.0
Voltage: 2.30 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
000 - -
Freeze Frame:
Fault Priority: 4
Reset counter: 167
Mileage: 180481 km
Time Indication: 0
Date: 2015.03.26
Time: 16:12:01
Freeze Frame:
(no units): 0.0
Temperature: 3.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 33
Reset counter: 62
Mileage: 183707 km
Time Indication: 0
Date: 2015.05.04
Time: 10:25:54
Freeze Frame:
(no units): 35.0
Temperature: 18.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1120403
Coding: 0032364
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:41:24
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 196
Mileage: 216720 km
Time Indication: 0
Date: 2016.04.23
Time: 05:41:24
Coding: 0221208
Coding: 0010900
1. Did you check the battery level on the MMI screen? Hit or miss if it shows an accurate reading but if it shows anything less than 100% I would replace. When was the last time you had a new battery? Module 61 shows no errors but I am no familiar enough with the module to know if the low battery would cause an error there
2. It isn't had to delete out all of the NO FAULT modules before posting so please do. Makes it a lot easier to see what is going on.
3. Did you check Ross Tech's wiki for any of the codes?
2. Sorry, will do going forward
3. Yes, nothing there for almost all of these codes
AudiWorld Wiseguy
Clear the codes, rescan after a short drive and post the results from that up.
Although the bank 2 too lean code is what I'd be focusing on for now. Most likely a vacuum leak.
W12 plugs are pretty long reach as plugs go. Nothing came out bent on the tips, correct?
Question - On the scan above, I did a scan - cleared all codes, went for a drive, came back and scanned again. Then saved that and it is what I posted above. I thought these were all current codes, but after you said to rescan - i looked and saw that many of these codes are old based on date -stamp. Sorry for that
Sorry - I thought I followed procedure for getting current codes for VAG Scan, based on what I have seen on forum and RossTech. What could I be doing wrong that it is not erasing old codes?
How to clear codes for real (VCDC clear all command doesn't work)
