engine oil level check light every other day???
Hi Guys,
I have been getting this low engine oil level light almost every other day. I open up the hood, check the dipstick and it's ok. Light goes away, then in 2 days, comes back on again and it repeats itself all over again....
Any ideas what could be wrong? What kind of sensor and where is it? Is it easy to replace?
Thanks in advance....
Probably a wonky sensor. It's typically located in the side of the oil pan.
#10 in this diagram
It requires an O-ring so it would be logical that it is outside.
My Bentley is offline right now and I don't have erWin docs for D3 or I'd look up procedure.
It was on the bottom outside of the pan. Took < 10 minutes. Held in by 3 simple 10mm hex head bolts. Pretty much requires an oil change unless you are super quick since it opens up about a one inch hole right in the bottom of the pan.
Hi Guys,
2k6blacka8
New Member Welcome Area
08-30-2015 04:13 PM
2k6blacka8
08-30-2015 02:07 PM
