error code help
Ran VAG-COM scan on audi for the first time and came back with the code listed below, can someone please advise what the issue here is. i am having a hard time figuring it out.
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0001TE.
Coding: 0532707
Shop #: WSC 06121 444 57461
VCID: 264310139112D62ECEF-8073
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 3488A
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB400846991Fÿ†63
Subsystem 5 - Serial number: 46991Fÿ†63428RB4008466FCUÿ†63
Subsystem 6 - Serial number: 466FCUÿ†63528RB40084691EMÿ†63
Subsystem 7 - Serial number: 4691EMÿ†63628RB40084689BRÿ†63
Subsystem 8 - Serial number: 4689BRÿ†63729RB4008CBA0C-ÿ†63
Subsystem 9 - Serial number: CBA0C-ÿ†63829RB4008CBA30Sÿ
Subsystem 10 - Serial number: CBA30Sÿ
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 197
Mileage: 250568 km
Time Indication: 0
Date: 2017.02.02
Time: 00:00:07
Coding: 0532707
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 197
Mileage: 250568 km
Time Indication: 0
Date: 2017.02.02
Time: 00:00:07
Component protection active means that one or more of your airbags where replaced with used ones. Dealer can remove that CP, but I believe it won't make any difference. I can't imagine that airbag won't work because of CP.
Thank You Mishar, is it possible to figure out which Air bag it was using VAG?
Boosting1Bar
02-01-2002 09:36 AM
