Error for secondary air system
Hello all. Im a new D3 A8 owner and have a couple problems that I just can not solve. I received two errors for "Bank 1, secondary air system, flow too low- lower limit not reached" and "Bank , secondary air system, flow too low- lower limit not reached" with DTCs of 17831 and 17819, respectively. I happened to notice this line was broken and hiding behind the engine. I cannot find out what it connects to or how to repair it. Any help?
Search for SAI ports or SAI Injection --It's a tiny stupid emissions thing that only runs when the car is cold but will throw a CEL and thus you won't be able to pass inspection.
That rubber hose connects to a small diameter synflex tube that goes under the fuel rails on that side of the engin which goes under the front engine decorative cover. It connects to a Tee on the opposite front side of the engine. The tee has two rubber hoses that connect to the two servos there which control the intake manifold flaps.
Excellr-A8
01-11-2008 06:01 AM
A4RIP
04-13-2002 03:34 AM
