Euro parking lights, some help Please
Banned
2005 A8L W12
Enable Euro parking lights that turn on signal at night
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 0 - Set to 1
OK here is my problem, I go into "09 Cent. Elect." then click on "07 coding", the box appears but there is no "long code helper" unless I click on drop down and pick the bottom one, then the long code helper is there, I click on it and that page only has 3 bytes, no number 9 to choose from.
what am I missing ? I have done TV,VIM,RVC,seat belt chime,lowered 20mm 15mm,ROW for fogs frt& rear with high beams, I just cannot get this long code helper.
Thanks Johnny J J
Bit 0 - Set to 1
Thanks Johnny J J
Banned
2005 A8L W12
Bit 0 - Set to 1
Thanks Johnny J J
Bit 0 - Set to 1
Thanks Johnny J J
Friday,29,June,2012,00:00:57:10074
VCDS Version: Beta 11.3.0
Data version: 20110801
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1F 25 28
34 36 37 38 3D 42 46 47 4F 52 53 55 56 57 61 62 65 67 69 72
76 77
VIN: WAUMR44E25N0 Mileage:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1F-Sat. Tuner -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
3D-Special Function -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 07C-910-018-BHT1.lbl
Part No SW: 4E0 910 018 B HW: 4E0 906 018
Component: 6.0L W12/4V A ª0050
Revision: --H01--- Serial number: AUX3Z0E3763166
Coding: 0007773
Shop #: WSC 26118 444 64337
VCID: 1E37DA4BB593
2 Faults Found:
19713 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Regulation at Upper Limit
P3257 - 001 - Upper Limit Exceeded - Intermittent
18686 - Oxygen (Lambda) Sensor B2 S1: Negative Lead: Open Circuit
P2254 - 004 - No Signal/Communication - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 J HW: 09E 927 156 A
Component: AG6 09E 6,0L4V USA 0060
Revision: --H01--- Serial number: 0056319
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2A5F069BF9DB
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 C HW: 4E0 614 517 BD
Component: ESP 5.7 allrad H44 0330
Coding: 0007637
Shop #: WSC 02313 000 00000
VCID: 2341EBBF9EF1
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E3763166
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8BB0C531737
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H03 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
Shop #: WSC 26118 444 04958
VCID: 2443E8A39BFF
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 300IE037525206
Coding: 0010003
Shop #: WSC 00000 000 00000
VCID: 33611BFF2E11
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 E
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000066522
Coding: 1126737
VCID: 1C33D043A38F
Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Component: Sitzluefter BFS H02 010
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0133121
VCID: 316D11F7D40D
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7154293
VCID: 1C33D043A38F
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D6017081
VCID: 2B51039FF621
Address 11: Engine II Labels: 07C-910-018-BHT2.lbl
Coding: 0007773
VCID: 1E37DA4BB593
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041211
VCID: 2545F5A790C5
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 2443E8A39BFF
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012351
VCID: E5C535A75045
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 980 H HW: 4E0 920 980 H
Component: KOMBIINSTR. VDO H58 0210
Revision: D06 Serial number: AUDID3E3000019
Coding: 0016209
Shop #: WSC 26118 444 84500
VCID: 2C530083F32F
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 F
Component: Gateway H10 0080
Revision: 10 Serial number: 180040540880FA
Coding: FFFEFFDD1B7D0E
VCID: 2759FFAFEAC9
2 Faults Found:
00380 - Special Vehicle Control Module (J608)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Date: 2012.06.28
Time: 23:44:28
02218 - Satellite Radio (R146)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Date: 2012.06.28
Time: 23:45:27
Address 1F: Sat. Tuner
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
VCID: D8BB0C531737
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0220
Revision: 00000018 Serial number: 00000000027053
Coding: 0000000
VCID: E1CD21B7446D
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0011210
VCID: 285BFC93E7D7
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0010
Coding: 4071658
VCID: 2443E8A39BFF
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H44 1100
Revision: 00000000 Serial number: 378DP057521209
VCID: 387B2CD33777
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000508800109
Coding: 0003493
VCID: 1D35DD47B895
Address 3D: Special Function
Cannot be reached
Address 42: Door Elect, Driver Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0060
Coding: 0032492
VCID: 204BE4B38FE7
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040504200006
Coding: 0048766
VCID: 2759FFAFEAC9
Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000014478
Coding: 0000018
VCID: 2A5F069BF9DB
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000060251
Coding: 0010111
VCID: 1E37DA4BB593
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0060
Coding: 0032492
VCID: 204BE4B38FE7
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000632
Shop #: WSC 26118 444 102972
VCID: 1F49E74FB299
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000004
VCID: E2CF2EBB416B
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396DY057508708
Coding: 0000002
VCID: 316D11F7D40D
Address 57: TV Tuner Labels: 4E0-910-146.lbl
Part No SW: 4E0 910 146 G HW: 4E0 919 146
Component: TV analog TUNER H12 0300
Revision: 00000032 Serial number: 00000000002286
Coding: 0001006
Shop #: WSC 00000 785 00200
VCID: 2545F5A790C5
4 Faults Found:
00863 - Antenna 1 for TV (R55)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Date: 2012.06.28
Time: 23:33:33
00864 - Antenna 2 for TV (R56)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Date: 2012.06.28
Time: 23:33:33
00865 - Antenna 3 for TV (R57)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Date: 2012.06.28
Time: 23:33:33
00866 - Antenna 4 for TV (R58)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Date: 2012.06.28
Time: 23:33:33
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000006832
VCID: 204BE4B38FE7
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 9861710508
Coding: 344530393135313035412056413039383631373130353038
Shop #: WSC 20251 444 53435
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0032492
VCID: 1E37DA4BB593
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900031419
Coding: 0232326
VCID: DFC9274F7219
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000504060047
Shop #: WSC 12336 024 394758
VCID: 346318E32B1F
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 B HW: 4E0 907 383 B
Component: ANHAENGERELEKTR 003 0040
Coding: 0001001
VCID: 2341EBBF9EF1
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0032492
VCID: 1E37DA4BB593
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: 06.00.57 Serial number: 00067808720509
Coding: 0001308
VCID: 214DE1B784ED
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007522151
Coding: 0010900
VCID: 285BFC93E7D7
End ---------------------------------------------------------------------
Banned
Anyone ?
My 04 A8l 4.2 had it, I did not do it, nor did I know anything about it until one night when I signaled into a parking space and the stalk did not cancel, I had opened the door to get out and there was this steady chime sound, I checked all switches except turn stalk and nothing, so I got out and looked around and found the passenger side front and rear parking lights on , I thought it was a short, but then moved stalk to left position and only left front and rear on, so I came on here and found it was "Euro Setting", So why cant I do this for the 2005 ?
Thanks in advance Johnny J J
Anyone ?
Banned
Thanks for the lite bulb you turned on in my head, I don't know why I did not check them after I added the ROW setting that let's me have fog lites front and rear with high beams on, I was thinking that being I could not do the code, I didn't have them, well guess what, I have euro parking lites, the outer rear's LED's and front 5 LED's illuminate at a lower power on either side I chose.
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Thanks again, Johnny J J
Banned
And you can enable/disable this as you wish? How is it enabled and disabled?
I would like to do this mod on account that I can continue using my standard bi-xenon high beams, as well as driving with only my fogs on (which I can do now).
So in total, switching from the current U.S. setting to ROW, only enables this parking feature correct? Doesn't change anything else I currently have. As for my car I have the stock headlights and tail-lights, so which is it that would light up?
when I left the UK it was illegal to park an unlit car on an unlit road at night, it also prevents confusion with which way the car is facing, as it's illegal there to park a car facing the flow of traffic at night too...
K9
p.s. just checked mine and it has the parking lights 'activated' too, but mine is on 'ROW' settings....
K9
