External AV source 1 and 2 in MMI
Hi all,
I've some enquiries about MMI 2G system in Audi A8 2007.
1- How I can use the external AV source as there is no where I can see to plug any external device? And what is it for exactly?
2- some people say that I can use it by installing a specific av adapter that can be connected into the 20 pin red connector behind the DVD navigation in the boot. But I'm not sure how it can be done exactly. Here is a link for the this connector cable in eBay
CT29AU02 Audi A6 A8 2005 MMI TV Tuner RCA AV Upgrade Interface Input Adaptor | eBay
anyone can help please?
thanks.
thanks.
Banned
Hello, So I assume you have the CD/aux button a not just the CD button and when push CD button it goes through CD TV av-1 and av-2, or if you push CD and then source you see my attached picture,
If all this is present then you have the TV tuner in the trunk by the nav unit , and yes then you would get the AV input adapters in insert them into the 20 pin red connector to the TV Module.
This will allow you to use External connection 1 or 2 to come through the TV Tuner then straight to the LCD screen when asked for at the head unit. So for example
AV1 - DVD player
AV2 - Anything with A/V RCA'S
All selected from the head unit on the external source option.
Manual Video- In Adapter A6 4F, A8 4E, Q7 4L
Please disconnect the battery before starting installation.
The TV receiver has to be removed of the left hand side of the trunk (Q7 right hand side). Remove the 20-
pole red connector. Remove the red housing and put the single looms of the adapter into the black
connector as follows:
PIN-configuration:
[PIN 09 – Shield Audio left/right] [PIN 15 – Shield Audio left/right 2]
[PIN 10 – Audio signal white, left] [PIN 16 – Audio signal white, left 2]
[PIN 11 – Audio signal red, right] [PIN 17 – Audio signal red, right 2]
[PIN 12 – Video signal gelb] [PIN 18 – Video signal 2]
[PIN 13 - Video/ Shield ] [PIN 19 – Video/ Shield]
Video output (only for Hybrid-Tuner):
PIN 4 – Video Shield
PIN 5 – Video signal
PIN 6 – Audio Shield
PIN 7 – Audio left
PIN 8 – Audio right
For the AV input here is what I used pasted below, also here is my post on the install,
https://www.audiworld.com/forums/sho....php?t=2828960
Next is Kufatec GmbH & Co.
for cable-ling
33945
Video - In - Harness - Audi MMI
10,92 eur
2 x
http://www.kufatec.de/shop/en/Audi/A...rness-Audi-MMI
Business Name:
KUFATEC GmbH (The recipient of this payment is Non-U.S. - Verified)
Email:
info@kufatec.de
Business Contact Information
Customer Service URL: http://www.kufatec.de
Customer Service Email:
info@kufatec.de
Customer Service Phone:
+49 0455180810 -0
AV1 - DVD player
PIN-configuration:
PIN 7 – Audio left
PIN 8 – Audio right
for cable-ling
33945
10,92 eur
2 x
Business Name:
Email:
info@kufatec.de
info@kufatec.de
+49 0455180810 -0
Thanks "JohnnyJ" for such a useful reply.
1- is there a specific DVD player I can install it in the boot? If so how I can get a power for it?
2- can I use the DVD navigation as a dvd player for media?
3- in case I installed a DVD player, is it playable while the car moving?
Please help
Please help
I have bought the leads to do this I just need to know the pin numbers on the 20 pin plug. when looking from the rear of the plug i.e., the side in which you insert the leads which is pin 1, pin 2 etc.
Many thanks
Many thanks
Banned
I posted pictures for you in the other thread a couple of days ago for you...
https://www.audiworld.com/forums/a8-...-unit-2828960/
Hello guys! I just bought Audi A6 C6 2005 and i got Tv tuner 4E0 910 146 G. And i have only one question, PIN OUTS for external av 1 and 2 are the same? (9,10,11,12,13 and 15,16,17,18,19) ?
THANK YOU VERY MUCH FOR ANSWERS!
Hi, everybody! My car is 2008 Q7 4L with MMI 2g. Just connected Apple TV to the AV2 input. It works perfectly with the main monitor but OEM headrest monitors shows black and white video. As per manual it should be optionality to change coding of the video signal at the monitor menu but in reality no such option. Is there any idea how to solve this problem?
