When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Change to PAL or NTSC on all of them from the tvtuner
multiple unsuccessful attempts are done. At PAL no video at all, at NTSC black and white. When we where playing with options both on MMI and right monitor it become color but left still black and white
I've got all the av wiring organised on my q7 however I want to use a relay to turn on the android box so it doesn't draw a current when car is off anyone know where the nearest ignition on cable is at the rear of the car tried pin number 3 on the tv tuner but that seems to have a constant 12
I use the 12v to 5v usb cigarettes lighter to power on the Android box. Plug in every time I want to use it and unplug when not needed. You can use this way to turn on using ignition, I believe it's the same as A8. Try it and let us know if it works.
I also want to mount an MP5 player on external AV1 or 2.
The 20-pin plug of the TV set mounted on the car has a different pin order compared to the diagrams found on the forum.
Has anyone else encountered this problem?
tv tuner - 4FO 919 412 A
Audi A8 2005, 3.0 ASB
Thank you in advance
