Fault code on Address 05
Little help on this fault code:
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G4723677
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8BFD22F6B4752DE037-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 0
Reset counter: 79
Mileage: 103536 km
Time Indication: 0
Date: 2014.02.16
Time: 19:03:16
Just to let you know, today, the front suspension began to drop to the bottom when it's parked. When I start it up, it goes back to normal. Going for 65k oil change tomorrow so a little help on what I should be asking my S.A. would be great!
Thanks
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 79
Mileage: 103536 km
Time Indication: 0
Date: 2014.02.16
Time: 19:03:16
Thanks
http://wiki.ross-tech.com/wiki/index.php/00956
Try a new battery in the key if you haven't already.
Then clear codes, use both keys, scan again.
Thanks for the info!
