Full hydraulic fluid change amount
How many liters would it take to replace my Hydraulic fluid? I only have one liter and I'm not sure if that's enough. 2004 A8 L quattro
I assume this is power steering. I used the dilution method.
Vacuum the reservoir and refill with fresh fluid. Drive a day and do again. After three drain and fill cycles it looks like new fluid. Smells like fresh fluid also. Changed to Febi brand fluid. Way cheaper than the Pentosin used previously.
AudiWorld Wiseguy
+1. I did the same, although my fluid was in very poor shape and smelt very burnt so I did a flush with plain old PS fluid first. A liter of that and a $5 fluid pump from autozone, followed by a liter of the specced (pricey) Pentosin stuff.
Did it a year ago now, all good.
Ah, I have a lot of Pentosin left over from doing a suspension fluid flush when I had the Merc, maybe I should do the same for the Audi's power steering, since I have it anyway. I use a turkey baster for it.
AudiWorld Wiseguy
it’s probably never been done (mine never was as far as I could tell) so it will be in a right state. Mine was jet black and very burnt smelling so in desperate need!
AudiWorld Wiseguy
