Glovebox vibration driving me crazy
#11
I'm sure there's a TSB on ELSA for this (and many others)
It involves attaching adhesive felt strips.
Would look it up, but I use Mac OS X at home which means no Windows/ELSA easily..
#12
#14
After removing the glove box (see instructions in this Thread), on the right hand side you can see the back of the fuse housing and it’s associated wire bundle. The black housing doesn’t fit snugly into the white fuse frame, the small white clip that holds the black housing in is about 1/2mm too long which gives the black housing some play. This play then allows the wire bundle to slap the frame which causes the muffled rattle we hear. I just super glued the black fuse housing into the white frame and put a little extra glue between the wire bundle and the metal frame to keep that from ever moving again. Solved.
alms_TT_ny
New England Discussion
07-01-2008 03:23 PM
finallyturbos
12-02-2005 07:49 PM
DirtMonkey_NWB6S4
02-12-2003 06:18 PM
Drewsmith3
11-24-2001 03:56 PM
