Got my VCDS and Checked Codes
Did an initial scan on my S8 and here are my results:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H5753858
Coding: 0410624
Shop #: WSC 02313 785 00200
VCID: 58BFF14FEBFA2FFE66-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00192 - Rear Left Door Handle Touch Sensor (G417)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 7
Reset counter: 64
Mileage: 88000 km
Time Indication: 0
Date: 2016.05.25
Time: 14:31:44
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000152535
Coding: 0106833
Shop #: WSC 02311 785 00200
VCID: 1C37AD5FDF4283DE82-8048
1 Fault Found:
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 88535 km
Time Indication: 0
Date: 2016.05.27
Time: 11:38:06
Freeze Frame:
Temperature: 29.0°C
Not too concerned with these but I saved then cleared and then ran again. The Auto HVAC code remains and the other went away. AC works great so don't know what is causing that.
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 64
Mileage: 88000 km
Time Indication: 0
Date: 2016.05.25
Time: 14:31:44
Coding: 0106833
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 88535 km
Time Indication: 0
Date: 2016.05.27
Time: 11:38:06
Freeze Frame:
Temperature: 29.0°C
Keep an eye on your HVAC Blower and Blower Control Module. Mine popped that code and then an intermittent voltage code. The HVAC blower would respond intermittently (turn the car on and it would stay off...cycle power and it would come on) until it finally stopped work. Ended up being a bad fan that shorted out the control module. Not sure why it popped up under the Dash Control Unit Part 3 instead of the actual failed part # but I chalked that up to German Engineering.
Part Numbers below for my S8:
4E0-959-101-A Blower Motor
4E0-820-521-C Blower Control Module
jeffry
05-17-2011 01:25 PM
