Halogen Parking Light to LED SWAP (pic intensive)
#11
A little finesse with the airbox an it goes together like magic, remember patience..
I THINK that a DRL is an automatic feature that turns on automatically when you start the car..
In this case we are physically switching it on.
Parking lights are the lights that turn on when you turn your lights on, on the first setting (ours is 2nd setting cause of the Auto ON feature)the parking lights turn on, the AMBER color it all depends on the vehicle or it could be that it looks amber cause it is halogen bulb "EWWW"
Anyways what ever they are called they were changed cause they looked horrible before, Call them what you want just get them changed you'll be thankful you did it YOURSELF..
Dont forget i also have a write up on the Courtesy Step light bulb right under the door) Halogen to LED write up.
https://www.audiworld.com/forums/sho....php?t=2783733
Wow I waited 3 months to change the Parking lights.
#12
Fantastic
Absolutely great writeup, should be a sticky for sure!
I'm completely car illiterate but with this writeup I am going to order the bulbs and install them myself this weekend hopefully.
Thank you very much!
#13
Maybe you can do another writeup with pics of putting the airbox back together!! I'm always afraid of pulling or pushing too hard and loosening the intake tube back where it meets the throttle body or whatever is back there.
#14
FYI, the OEM bulbs (#194) are not halogen, they are incandescent bulbs.
#15
Also, when you have your normal driving lights on these are on as well? You should post up a picture of your lights on as well as the parking lights, assuming they are both on at the same given time.
#16
Nice write up. I am doing the swap this weekend. I just got the error code for the hologen light for the DRL so I figured I would just change both with them LED lights. Thanks for the detailed write up!
#18
That is truly an awsome write up but as I understand it olny works for the parking light. I really want to change y DRL for an LED and can't find the replacement bulb. Is there one?
