Head Gasket Failure
#21
Banned
I would not do that either !!!!!!!!!!!!
I mean no disrespect, But no sealer should ever be used in an Audi, this is of course straight from Audi, and being you had some luck with what you did use, I would not push it further, Bars leak is the worst stuff you could use, that crap clogs everything.
Yeah Bars Leak worked for our old crap cars just to get us by for the time being, but no long term fix.
#22
I mean no disrespect, But no sealer should ever be used in an Audi, this is of course straight from Audi, and being you had some luck with what you did use, I would not push it further, Barrs leak is the worst stuff you could use, that crap clogs everything.
Yeah Barrs Leak worked for our old crap cars just to get us by for the time being, but no long term fix.
#23
Banned
"What I have found with sealants is if they seal the leak they can also cause restrictions of flow in other areas of the cooling system, such as the radiator."
http://barsproducts.com/catalog/view...-hg-1/comments
http://barsproducts.com/catalog/view...-1186/comments
#24
Holding off on anything for awhile till I see if head gasket holds.
Found lots of info on these new products. Surprised it worked.
I thought water pump seal was on outside of pump bearing?
Anyone have more knowledge of water pump design?
#25
Seal is on the inside of bearing, or between water and bearing. Little dripping hole is in between. Bearing is also sealed by itself, but that seal is not really strong. If you get any pressure there coolant will get into the bearing and it wont stand that for a long.
#26
I am also surprised that it worked, but let's be optimistic.
Thank you.
#27
It is actually same as timing belt job. Just be sure to do your homework before you decide to do it. Far from not doable, but not really simple either. You need a timing belt tool too.
#28
Update at about 1200+ miles!!! The head gasket seal is doing great. No #2 cylinder misfire at starting has not come back!!! Having hot weather here in mountains, 80 to 90+ degrees every day with no cooling problems at all. The $18 head gasket sealer is a miracle!!!
Against others advise I added BARS stop leak to cooling system. IMMEDIATE RESULT is water pump leak stopped completely.(after just 10 miles of driving) It worked so well it's unbelievable! Been over 2 weeks and I have not seen a drop on garage floor, I check every day!!(I have left engine cover off).
I have used BARS with other cars with plastic radiator tanks. Worked on other Audi's and VW's All I can say is water pump seal is better, only time will tell. I was going to drain cooling system to replace with new coolant but now I am thinking of leaving it a while longer.
#29
Rog,
Congrats, I'm glad you got it done, fixed it, but I still have questions about these leak sealer - how does it do it? Can someone explain it to me? I can't imagine this "stuff" flows with the coolant and find the leaks, fills it up (just the leak cracks?), cures itself and seal the leaks. This is amazing to me. How does it know which flow is a leak and which is a valve?
Thanks,
Louis
Thanks,
Louis
