Headlight control range failed...
AudiWorld Expert
Yellow suspension car and the *** end of my car is dumped. wtf. is it the level control system? Any known immediate fixes or is it aftermarket warranty time? its on 04. It was fine last night...fired it up today and boom.
AudiWorld Expert
From the VAG Com...Clearly there is no communication to the level control system. Checked the fuse on the right side for adaptive suspension (10 amp) and it was fine. Search pulls up related incidents, but nothing revealed my problem of just the back suspension draining completely.
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000005505043
Shop #: WSC 08153 444 54333
VCID: 1E38C87BB0DF
Part No: 000 915 105 AK
Component: von VA0 1311070600
Coding: 303030393135313035414B56413031333131303730363030
Shop #: WSC 00000 128 00289
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 143
Mileage: 134752 km
Time Indication: 0
Date: 2010.07.23
Time: 22:19:17
Additionally...
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 0200503B201028
Coding: FCFE7BDD1B2304
Shop #: WSC 02313 785 00200
VCID: 2648E09BE88F
1 Fault Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 143
Mileage: 134752 km
Time Indication: 0
Date: 2010.07.23
Time: 14:45:55
VCID: 1E38C87BB0DF
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 143
Mileage: 134752 km
Time Indication: 0
Date: 2010.07.23
Time: 22:19:17
Additionally...
VCID: 2648E09BE88F
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 143
Mileage: 134752 km
Time Indication: 0
Date: 2010.07.23
Time: 14:45:55
AudiWorld Expert
Disregard. I fixed it myself today. I used this post as a reference. I went to check the 40 amp fused described in said post that is near the drivers knee airbag. While it was fine. I heard the car click when I started to plug it back in. Just for the hell of it, I fired the car up without the fuse. The yellow car light stayed on, but the green one was flashing. I shut the car off, plugged the fuse in and it immediately raised the back of the car back up.
Said post
https://www.audiworld.com/forums/sho...ght=yellow+car
Said post
Devon Huerta
06-10-2018 08:50 PM
Projekt 8E
07-03-2011 07:26 AM
