headlight wiring schematic
does anyone have the headlight wiring schematic for an 06, I am going to try and remove the bulb out warning light with some load resistors.
Not Advised! It's been documented that some Model Years will not take the LED Conversion! I'm assuming that this is your issue and not the Headlights which should not give you a Warning when simply changing bulbs (HID). Laters,
Sorry guys, what I meant way the daytime running lights. My headlights are xenon. I put LED bulbs in the DRL and am getting the warning.
I have also tried the load resistors in the head light housing and it works to get rid of the warning but my problem is the housing is all plastic and the resistors heat up a lot so I was going to mount them to something metal outside the headlight housing
Ok cool, I pickup my car from the states though. It has te option to turn on or off the DRL they were jut regular bulbs till I changed them to LED
Which ones are those? 35W halogen just next to HID's? If so, they can be set to work as high beams giving way more light all together.
I don't know that DRL setting but I like it. It is way better than using HID's all the time.
I think those are the ones. I'm not really looking to set them as high beams though. I like the look of the bright white LED's. Just need to know where the wires run so I can install a load resistor.
