Help :) - Cylinder misfire 4.2L V8
Today I got the EPC light and the exhaust light warning in the dashboard.
The VAG COM tell me this (did two readings/cleared all DTC1s):
1. READING
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 E HW: 4E0 907 560
Component: 4.2L V8/5V G 0040
Revision: 00000000 Serial number: AUX3Z0C0307848
Coding: 0011773
Shop #: WSC 00210 218 81611
VCID: 234E06B1E28F70001C7
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
16685 - Cylinder 1
P0301 - 001 - Misfire Detected
17718 - Cyl. 10 Ignition Circuit
P1310 - 001 - Short to Ground
Readiness: 0110 1101
2. READING
Coding: 0011773
3 Faults Found:
P0300 - 001 - - MIL ON
16685 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON
P1310 - 001 - Short to Ground - Intermittent
Readiness: 0000 0000
What does the difference in this readings mean? Readiness and MIL ON??
Also, what does Cyl. 10 mean?
And last how do I find the numbers on the cylinders? To check the spark plug in cylinder 1?
-A-
1. READING
Coding: 0011773
3 Faults Found:
P0300 - 001 -
16685 - Cylinder 1
2. READING
Coding: 0011773
3 Faults Found:
16685 - Cylinder 1
-A-
Cylinder 1 is on the left, closest to the front end of the vehicle.
Looks like a bad coil pack to me.
Has the TSB ever been done for that [think free coil pack/labor] ?
Check VIN here http://www.audiusa.com/us/brand/en/o...in_lookup.html
Readiness: http://www.ross-tech.com/vcds/tour/readiness.html
See also here http://audiforum.us/threads/engine-t...detected.9041/
The Readiness Code is a set of 8 bits, each of which corresponds to one monitored emissions "system" in an OBD-II car. When all readiness bits show "Passed", it means that all systems have been checked and have passed the on-board tests. The Readiness screen shows the name of the script in the title bar and under the [Set Readiness] button, or gives a reason why [Set Readiness] is disabled when that is the case.
Badly worn spark plugs ( shortened electrode causing too large of a gap) can cause this. My son had this on his TT he just bought. Put in some pullout plugs from my Beetle and all is well. The gap was almost .1"
snatchman
07-27-2017 06:32 PM
Nate (ETKA+Scumbag)
01-31-2007 03:36 PM
