Help me get my menus back in MMI(Also posted in Vag-Com)
I recently diagnosed and replaced a bad Control Head for the MMI in my wife's 04 A8 thanks to this forum and VCDS. I installed a refurb Control Head purchased from a vendor here and took it to the dealer to remove the Component protection. All the features that show work but it seems that I'm missing a bunch of stuff under the "Car" menu. The main one being the air suspension settings. Is there a way to reactivate these menus?
Banned
Hello,
you can try this below, or the link from this site, BUT WHAT EVER YOU DO, STAY AWAY FROM THE BOOTLOADER IN MMI MENU !!!!
https://www.audiworld.com/forums/sho....php?t=2823369
Or follow this, skip the vag if you have activated hidden menu previously.
use Vag-Com and do the following:
Connect VAG-COM
Select Control Module "07", Click on "Adaptation"
Select Adaptation Channel: 08
0-Hidden Menu Disabled
1-Hidden Menu Enabled
Enter value "1"
Click "Test", followed by "Save"
Close & reboot MMI by pressing "Tel" + "MMI Control ****" + "Upper Right Selection Button" (all together)
Press "Car+Setup" together until hidden menu appears, takes about 5 seconds
Then scroll down to Diag Settings and press enter
Then scroll down to Car Menus Maske (this is how it is spelt on the UK MMI) press enter
The find Battery Level and press enter
Scroll down the the bottom and press Accept Changes
Press the return button 3 tmes to return to the front screen
Connect VAG-COM
Enter value "1"
Thank you so much JohnnyJ for ponting me in the right direction. I got most of my menus back but cant seem to find the one to turn on/off the solar sunroof. I added the code for sunroof but it didn't add that menu. NBD.
Anyone have a list of what all the channels do/have?
Again, Thanks.
Again, Thanks.
ELEVENS
RS4 (B7 Platform) Discussion
01-31-2008 04:52 AM
Simkin
04-30-2002 12:58 PM
