Ignition switch module replacement on 04 A8L Quattro
Did anyone have to replace their ignition switch module? If so, did you get the key with it? Or no key.
Please, elaborate if you got another switch with a key...Did you have to reprogram the key? How?
Lastly, if you didn't get a key with the switch...Please explain. How did you reprogram the key you had? Feedback asap. Thank you.
I might ask why you are replacing it since it almost never goes bad? Perhaps the induction coil is bad?
Attached.
Yes, this is the part I'm talking about. The mechanic working on my car is stating this is possibly the problem why my car isn't starting.
I asked because if I get another switch will my original key work or should I get a switch with key included. I was told by a worker from Audi parts the key I use may need to get reprogrammed.
Thanks, for replying back.
yonyu
11-19-2008 10:28 AM
El Desamparado
Audi Original "S" Cars
10-12-2006 06:14 PM
Mr Paul [T-28]
07-27-2006 03:29 AM
