Installed AMI but now says tv/dvd player not installed?
#12
Regarding VAG-COM coding, there is a parameter in the MMI that tells it how many devices to look for on the MOST ring, so you need to change this from 1 to 2 if you have both the CD and AMI installed.
#13
Newest software has multiple meanings to me, so can you confirm that the MMI software is at least s/w level 33.60? Were all the software updates applied before or after the AMI install? I believe that AMI s/w updates won't be applied if you do the software upgrade before the AMI is installed.
#14
Don't despair - you are getting closer to a solution!
I guess I was one of the lucky ones who just plugged mine in and slid it right next to the cd changer. It worked without having to mess with VAG-COM, which I was prepared to do.
Sounds like you need to get or borrow VAG-COM and change the settings as previously described by MP4.2+6.0. Last resort is just take it to the dealer and have them set it up. Good luck.
#15
#16
i bought the cd's last night online, when i get it do i just plug car's battery to charger and throw in the update disc inside the cd changer and let it run its course?
Magnvs
08-01-2013 11:27 PM
Emauss
03-22-2008 10:32 AM
MoyImola
12-29-2004 11:21 AM
Marian (1.9tdi)
01-31-2002 06:14 AM
