instrument cluster keeps turning off while driving
I have recently experienced problems with my 2007 Audi A8L. The instrument cluster turning off while driving.
Anyone else experienced this before? Sorry if it's a double post but I couldn't find anything related to this in the search.
Haven't gotten my Vag-CoM yet due to the postal strike in Canada.
just wanted to elaborate more on my previous post:
The cluster will completely turn off, speedometer and tachometer drop to 0 along with all the other gauges. Headlights stay on and car runs as usual. MMI doesn't turn off and keeps functioning.
After a few seconds the cluster turns on again, time is reset to 0:00.
Lately it's been turning off once every minute of driving. Unplugging battery overnight to see if that helps
my cluster was replaced during the first 3000 miles of ownership. 06 A8L,
the needles were shuttering and the cluster went off completely...with all the associated alarms chiming! apparently had to be ordered specific for the car. You may want to attempt to find out if the tech has taken one out before as it's easy to break the plastic vents and mark up the opening to the right and left of the cluster when removing it. best of luck!
no errors on mine. they don't flutter either just turn off/on as if nothing happened. Going to check with the vag-com for errors once i get it
Yes, run VAG-COM
and yes could be a loose connector or something. Not an issue posted about much on the board over the years. Hopefully VAG COM gives you a better sense of where the issue is.
thanks for the tips, everyone.
I will update once i get the vag-com unit. If no errors i'll take off the trim and check connectors on the cluster.
I was wondering if anyone knew which module stores the date/time for the vehicle. I noticed the vehicle reboots/resets even when the car is parked overnight and when I go look at the time its either 0:15 or 0:10 which means it resets probably every fifteen minutes.
vagcom results
Ok finally got my Vag Com so here are the results:
Sunday,06,November,2011,17:16:20:53686
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 4L0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 28 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUMV44EX7N022730 Mileage: 45150km/28054miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Sporadic communication error 1000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: 71H21--- Serial number: AUX3Z0G3722333
Coding: 01060009190F0120
Shop #: WSC 02313 785 00200
VCID: 2045E0958A58
1 Fault Found:
005748 - Powertrain Data Bus: Implausible Message from Instrument Cluster
P1674 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 44835 km
Time Indication: 0
Date: 2011.09.03
Time: 03:35:10
Freeze Frame:
RPM: 1467 /min
Load: 35.3 %
Speed: 64.0 km/h
Temperature: 99.0°C
Temperature: 24.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.478 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0030
Revision: --H01--- Serial number: 4328209
Coding: 0000002
Shop #: WSC 02313 758 00200
VCID: 234FEF999B4E
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2241EA9D8454
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G3722333
Coding: 0410624
VCID: D8B508751288
Part No: 4E0 905 852 E
Component: ELV 1940
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 244DEC859E40
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348DP077524090
Coding: 0000003
VCID: 336F1FD92BAE
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 113
Reset counter: 40
Mileage: 43728 km
Time Indication: 0
Date: 2011.07.30
Time: 00:00:37
Freeze Frame:
Bin. Bits: 01
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000121441
Coding: 0102737
Shop #: WSC 02311 785 00200
VCID: 1C3DD465A630
Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Component: Sitzluefter BFS H02 010
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133124
VCID: 366926CD38DC
Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785
Component: SG ext.Player H09 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 2B5F07B9F39E
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 200
Mileage: 44808 km
Time Indication: 0
Date: 2011.09.03
Time: 00:39:08
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0080443
VCID: 2C5D04A5F690
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H14 4230
Revision: 91H14423 Serial number: 0037Q0G0347N
Coding: 0532707
VCID: 2649F68DE87C
Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012141
VCID: E5CB318155FA
Part No: XXXXXXXXXXX
Component: Lenkradmodul H02 0030
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 254
Reset counter: 217
Mileage: 0 km
Time Indication: 0
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0530
Revision: D05 Serial number: AUDID3G4003869
Coding: 0048563
Shop #: WSC 22122 444 54375
VCID: 254BF181957A
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B075048236
Coding: F5F5DF7F707A0E
VCID: ECDD44A5B610
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 210
Reset counter: 217
Time Indication: 0
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Priority: 1
Reset counter: 217
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046004 Serial number: AUZ5ZBG3402019
VCID: 1A31D27DAC04
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000019 Serial number: 00000000054888
Coding: 0000000
VCID: E1C3259141D2
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A5102BDFC64
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
VCID: 244DEC859E40
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H49 0990
Revision: 00000000 Serial number: 381ER077523473
Shop #: WSC 22122 444 92498
VCID: 316315D1D1B2
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000711000022
Coding: 0003477
VCID: 1D3BD961BD2A
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 217
Mileage: 0 km
Time Indication: 0
Date: 2011.09.10
Time: 00:01:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
VCID: 2045E0958A58
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040705140250
Coding: 0048702
VCID: 2A5102BDFC64
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000008372
Coding: 0000026
VCID: 2C5D04A5F690
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000116137
Coding: 0010111
VCID: 1E39DE6DB02C
Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
1 Fault Found:
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Freeze Frame:
Fault Priority: 3
Reset counter: 217
Mileage: 0 km
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
VCID: 2045E0958A58
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000922
VCID: 2045E0958A58
2 Faults Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 77
Time Indication: 0
Date: 2011.06.23
Time: 00:00:04
Freeze Frame:
Voltage: 13.46 V
Count: 61
02441 - Yellow Malfunction Lamp in Instrument Cluster
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 201
Mileage: 44832 km
Time Indication: 0
Date: 2011.09.03
Time: 03:35:10
Freeze Frame:
Voltage: 13.46 V
Count: 63
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 2953FDB1F962
Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396EX077573612
Coding: 0000002
VCID: 316315D1D1B2
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000005784
Shop #: WSC 00000 128 00289
VCID: 2045E0958A58
Part No: 4E0 915 105 A
Component: von VA0 2705210661
Coding: 344530393135313035412056413032373035323130363631
2 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Mileage: 44956 km
Time Indication: 0
Date: 2011.09.17
Time: 00:00:02
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 0 km
Time Indication: 0
Date: 2011.09.17
Time: 00:01:16
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
VCID: 1E39DE6DB02C
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900051638
Coding: 0232125
VCID: 2045E0958A58
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000705140099
Shop #: WSC 12336 024 394758
VCID: 346D1CC52EA0
Address 6C: Back-up Cam. Labels: Redir Fail!
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7410RI
Coding: 1120503
VCID: DCBD146566B0
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
VCID: 1E39DE6DB02C
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720713603556
Coding: 0221208
VCID: 234FEF999B4E
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007572327
Coding: 0010900
VCID: 2855F8B5E268
End ---------------------------------------------------------------------
Chassis Type: 4L0
VCID: 2045E0958A58
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 44835 km
Time Indication: 0
Date: 2011.09.03
Time: 03:35:10
Freeze Frame:
RPM: 1467 /min
Load: 35.3 %
Speed: 64.0 km/h
Temperature: 99.0°C
Temperature: 24.0°C
Voltage: 14.478 V
Coding: 0000002
VCID: 234FEF999B4E
Coding: 0007597
VCID: 2241EA9D8454
Coding: 0410624
VCID: D8B508751288
Component: ELV 1940
Coding: 4071648
VCID: 244DEC859E40
Coding: 0000003
VCID: 336F1FD92BAE
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 40
Mileage: 43728 km
Time Indication: 0
Date: 2011.07.30
Time: 00:00:37
Freeze Frame:
Bin. Bits: 01
Coding: 0102737
VCID: 1C3DD465A630
Coding: 0133124
VCID: 366926CD38DC
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Revision: 00000000
Coding: 010000
VCID: 2B5F07B9F39E
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 200
Mileage: 44808 km
Time Indication: 0
Date: 2011.09.03
Time: 00:39:08
VCID: 2C5D04A5F690
Coding: 0532707
VCID: 2649F68DE87C
Coding: 0012141
VCID: E5CB318155FA
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 217
Mileage: 0 km
Time Indication: 0
Coding: 0048563
VCID: 254BF181957A
VCID: ECDD44A5B610
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 217
Time Indication: 0
Freeze Frame:
Fault Priority: 1
Reset counter: 217
VCID: 1A31D27DAC04
Coding: 0000000
VCID: E1C3259141D2
Coding: 0015510
VCID: 2A5102BDFC64
Coding: 4071658
VCID: 244DEC859E40
VCID: 316315D1D1B2
Coding: 0003477
VCID: 1D3BD961BD2A
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 217
Mileage: 0 km
Time Indication: 0
Date: 2011.09.10
Time: 00:01:00
Coding: 0032364
VCID: 2045E0958A58
Coding: 0048702
VCID: 2A5102BDFC64
Coding: 0000026
VCID: 2C5D04A5F690
Coding: 0010111
VCID: 1E39DE6DB02C
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 217
Mileage: 0 km
Time Indication: 0
Coding: 0032364
VCID: 2045E0958A58
Revision: --H03---
Coding: 0000922
VCID: 2045E0958A58
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 77
Time Indication: 0
Date: 2011.06.23
Time: 00:00:04
Freeze Frame:
Voltage: 13.46 V
Count: 61
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 201
Mileage: 44832 km
Time Indication: 0
Date: 2011.09.03
Time: 03:35:10
Freeze Frame:
Voltage: 13.46 V
Count: 63
Coding: 0000018
VCID: 2953FDB1F962
Coding: 0000002
VCID: 316315D1D1B2
VCID: 2045E0958A58
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 44956 km
Time Indication: 0
Date: 2011.09.17
Time: 00:00:02
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 0 km
Time Indication: 0
Date: 2011.09.17
Time: 00:01:16
Coding: 0032364
VCID: 1E39DE6DB02C
Coding: 0232125
VCID: 2045E0958A58
VCID: 346D1CC52EA0
Coding: 1120503
VCID: DCBD146566B0
Coding: 0032364
VCID: 1E39DE6DB02C
Coding: 0221208
VCID: 234FEF999B4E
Coding: 0010900
VCID: 2855F8B5E268
