Intake manifold
2008 A8 4.2 FSI 144,000 miles
I'll be walnut blasting the intakes shortly. While I have everything apart, I'll also change out some other gaskets and parts.
Here is what I have so far:
Intake manifold gaskets
valley pan gasket
Both valve cover gaskets
Oil filter housing double Oring and single Oring
PCV fine oil separator
oil check valve
Oil spray valve
And adding an oil catch can
Anything else I should replace while that's all apart and easy to get to?
Thanks
valley pan gasket
oil check valve
Oil spray valve
Thanks
valley pan gasket
oil check valve
Oil spray valve
Thanks
valley pan gasket
oil check valve
Oil spray valve
Thanks
Plan to clean the throttle body with the assemble out and easy to access, and perhaps ditto for the MAF w/ some MAF or electronic (no residue) spray cleaner.
Thanks
![](https://cimg4.ibsrv.net/gimg/www.audiworld.com-vbulletin/1500x2000/img_20170913_150226922_1378e8dafb46d8babbf2ff8d48420ee77caedbbd.jpg)
![](https://cimg6.ibsrv.net/gimg/www.audiworld.com-vbulletin/1500x2000/img_20170913_150241733_25a555e697c36eaeff18d5846208de2c5585b517.jpg)
![](https://cimg8.ibsrv.net/gimg/www.audiworld.com-vbulletin/1500x2000/img_20170913_155106960_38e09a7717e68c50c9c4af422faef995ec482ab3.jpg)
![](https://cimg9.ibsrv.net/gimg/www.audiworld.com-vbulletin/1500x2000/img_20170914_130754034_64938f1f368275b2dd46cf3d2e411259a012369b.jpg)
Valves have been walnut blasted and scrapped. The carbon was so thick in 2 of the valves that I don't think much air was even getting by. By the time I scrapped the walls and the valve, the intake was full of carbon. Then I did walnut blasting, soaked it with oven cleaner, scrapped, more blasting, and wiped it clean.
I got the valley gasket and oil filter gasket changed, as you can see, there was a big leak.
Put it all back together, went to start the car, and it kicked and bucked. Lots of misfires. Cylinder 1,6,7,8 all misfires, throttle sensor errors, manifold flaps stuck closed. Cleared everything, restarted the car, less bucking, misfire on #1 only. Cleared faults, revved it up, smoothing out. Cleared codes one last time, started it back up.....smooooooth as silk!
Hit the road, and the power is back!
thanks for the pics! I had no idea it would be that gunky. Now I'm all paranoid that that is what mine looks like inside too. I'd probably do that if something else goes bad that involves manifold removal. I did change my fine oil separator without removing the manifold.
thanks again
thanks again
Yes, that was a big factor. I have the stuff to add an oil catch can. It'll be interesting to see how much oil it catches.
I also have the equipment and additives to do the BG induction cleaning. I ran 2 cans through my intake, plus their gas tank additives (yes, I know the gas tank additive does nothing for FSI, but it's what they do at the shop). This was done a couple months ago, as you can see, it's a complete waste of money once the carbon has built up. However, I will start to do this every oil change now that my valves are clean.
lskolnick(original)
10-18-2014 11:20 AM
zeems
Audi Original "S" Cars
11-26-2007 07:26 PM
elijahallen
12-09-2006 09:14 AM
DN
08-04-2003 02:35 PM
