Sponsored by:
Sponsored by:
Intermittent starting problem?
Old 03-28-2008, 09:23 AM
New Member
zambini's Avatar
Default Intermittent starting problem?
I've owned a 2004 A8L for about 2 months now. Once in a while, I'll attempt to start the car and it will seem like the battery is dead. According to MMI, the battery is ok. Once I click the key back and restart- it fires back up. Any ideas as to what it could be? Thanks.
Old 03-28-2008, 09:31 AM
greenie's Avatar
Default Yep! My 04 suffered from the same thing.
My dealer could not "duplicate the condition" which was their answer for just about everything so I learned to live with it.
Old 03-28-2008, 09:56 AM
gwelch's Avatar
Default Mine occasionally does the same thing.
It has always turned over on the second try.
Old 03-28-2008, 11:27 AM
knepster1's Avatar
Default Re: Yep! My 04 suffered from the same thing.
Very common on the '04, it will start on the second turn...happens to me once or twice a month. They looked at starter, alternator, connections, etc...no issues. Battery is at 100%.
Old 03-28-2008, 11:51 AM
BLUEDEVIL8995's Avatar
Default Re: Intermittent starting problem?
This happened to me this morning and happens about 2-3 times a month. I can never duplicate this with my SA.
Old 03-28-2008, 12:33 PM
mikesd1980's Avatar
Mine did the same thing till one morning I came outside to go to work and it didnt start at all. I got it towed to the dealer and they said it was the starter. After it was replace it didnt do it again. I had the car for like month and it did it the whole time till that special day. So hopefully you wont be in a bad spot when it dosent start.
Old 03-28-2008, 12:37 PM
New Member
scmalk's Avatar
Mine too!
Old 03-28-2008, 12:56 PM
The A8 Doc's Avatar
Mine does it occasionally and got to the point where it didn't start.
Replaced brake pedal switch,erased codes on ECU and fine ever since?
Food for thought!
Old 03-28-2008, 01:24 PM
Rowlie's Avatar
Default Mine does it, too. 2-3 times a month.
it doesn't seem to actually engage the starter the first try, then acts normally the second try. No help from dealer. It sounds like there should be a TSB with the problem being as common as it appears to be. Anybody know of one?
Old 03-28-2008, 02:12 PM
schnellmb's Avatar
Default Howdy Mr. Greenie....and Gina
how the heck are you doing? good to see you guys around.
Quick Reply: Intermittent starting problem?
