Level Control -34 will not save adaptation
I just replaced my valve block to clear the 01773 error code for valve accumulator N311..now the car is still in jack mode with errors 01781 - extreme vehicle inclined, 01780 - givers for vehicle level and 01437 - rule situation not learned. I tried adaptation several times even after driving the car around a while but it will not save - asks for security code as soon as I try to enter ch 5; channels 1 to 4 vlaues saved fine.
What are the givers for vehicle level?
I also noticed from the measuring blocks - group 5 and Vehicle Level Deviation - group 10 show rear left reading to be way off?
Group 5
Front/Left 109; Front/Right 108; Rear/Left 144; Rear/Right 83
Group 10
Front/Left 0.0; Front/Right 4; Rear/Left 31; Rear/Right -33
Thanks in advance for any assistance!!
Group 5
Group 10
Yes I know...I would enter the security code and go thru channels 1-4 saving all the values but when I get to ch 5 it reverts back to security code and does not allow me to save by entering 1??
Could be that it is timed out?
Generally that procedure is weird. It asks for the measured values and than it doesn't accept some of them, so you have to put something not measured in order to complete it. I did it few times and had to improvise with values in order to level the car.
Here they are:
Group 5
F/L 105 F/R 105 R/L 108 R/R 108
GROUP 10
All of them pulsing from 0 to 2 mm.
I am not sure if we where measuring same values in group 10. If we where than it looks like that something is way off with your rear sensors.
Group 5
GROUP 10
Group 5
Group 10
Group 5
Group 10
