Massage seat retrofit
#22
Just an FYI, I've had my '04 for over nine years now with heated, ventilated massaging front seats. I use the massage feature at most, three times a year. The passenger side gets used zero times and Mrs. Bally among other passengers do not care about it. IMO, do not waste your time or money on this feature. Now, the heat and ventilation features are used constantly six+ months out of the year.
#23
Had it on my W12 and the A8. The "massaging" seats are a joke. All it is, is a rolling lumbar and depending on what car or seats you have it is barely noticeable. It was a tad more noticeable in my W12 with the nappa leather seats vs the standard A8 with the standard leather.
#24
Hey i recently purchased a used 2006 Audi a8L and fell in love with everything about this car. But for some reason i cannot seem to get the massage function to work. i have the button on the side but it does not respond. im not sure if the heat and cooling work either but im sure it does on the passenger side. The menu comes up with and allows me to control both sides but i dont feel anything on the driver side. When i received the vehicle the air strut went out a week later, since its used-as is i must pay half....300 bucks. Other than that it a a dream come true. When i press the massage button should it say anything on the mmi, do i have to be in the ac menu to enable massage. do i have to be stopped??
#25
If your lumbar mechanism is not working, then you won't feel it. Massage doesn't have levels just a round button. If it works, lean back and feel the lumbar moving in and out.
#26
before you press the message button, expand the lumbar out until you feel it in your back...then move it up away from the seat....then press the button.
Our family loves this option and it gets used every time we are in the car. Great feature...shame folks don't adjust it and then try it out.
#27
If the lumbar is lowered and small, you may not feel it. Try this...
I myself at first thought "this is crap", then I moved the lumbar out with the 4 way switch, and it is very noticeable after.
#28
i need to become more active, i had no idea i would get answers. thanks for the responses. i will be more regular here now. I tried the lumbar adjustment and i still dont feel anything. i do not have heated or cooled seats working on my drivers seat, heated works on the passenger. Neither side notices massage. i will try again and be more tedious with it however i tend to believe the problem would be in a relay or mechanism that powers heated/cooled and massage. The panel switches on the inside has the massage button on the same unit as the seat movement. Testing the seat with a multimeter at all points would be hassle-some but worth it if its the only way.
#29
Always buy car with the options you must have. The massage turns off after 10-15 minutes, it must be controlled by the controller. The controller may share the same button with the air cool seat. Changing the controller may need to activate the options. It's not plug and play as one might think.
The timer on the massage seats are a safety issue, they don't design it stupidly.
neumanngroup
17
09-18-2020 01:29 AM
draadloos
05-01-2017 11:30 PM
