Misfire/P0303/ oil on spark plugs issues.
hi all,
2007 Audi A8 4.2 FSI
im getting a misfire on cyl#3, i’ve changed the coil and am still getting the same issue.
i did notice lots of oil on the tip of the coil and on the spark plug, im sure i need new gaskets and
am looking into it, but can the oil be the issue with the misfire? Or can it be an injector issue?
Symptoms are ge car runs rough with a slight sputter and shake when engine is cold and a little less when warm.
when I accelerate a little hard the engine light starts to flash.
Will appreciate he input.
I have never had a problem with misfires that was attributed to oil filling the shark plug cavity. I have had spark plug cavities completely full of oil and the car ran fine. Run a compression test. If all is OK, then I would check the wiring from the ECU to the coil. Make sure that cylinder # 2 and #4 are firing OK. Raw fuel being dumped into the exhasut manifold will disrupt the flow of exhaust gases enough to cause a misfire to adjacent cylinders.
AudiWorld Wiseguy
FSI motor....rough running/misfire....Black/oily plug....seriously coked up inlet valves is my guess.
Take it for a walnut shell blasting and it’ll be good as new.
You could try the BG chemical treatment. BG works with Audi VAG to come up with some innovative solutions. It will require that you have an air compressor, and some other tools.
Once cleaned, I'm sure it does its job if done with every ounce change.
hi all,
De carbonizing will also help a lot.
