MMI Doesn't switch to camera mode...
Hello all,
I took out the camera control module today to add a RCA jack for the video. Took out all the cables and disassembled the unit. Put it back, check the video FBAS input/output, the quality looks great except when I switch to reverse, the parking aid graphical is there but the MMI doesn't switch from TV AV1 to camera video.
Use VCDS to check, there were many faults, cleared and still didn't work, checked out the can gateway to see if RVC is still enable, it was. If you see anything from the codes, please let me know.
Thanks,
Louis
![](http://www.dognmonkey.com/media/audis/camera/problems/noswitch.jpg)
Control Module Part Number: 4L0 910 468 A HW: 4L0 907 468 B
Component and/or Version: J533__Gateway H06 0060
Software Coding: F5D5FF7730720E02
Work Shop Code: WSC 02335 785 00200
6 Faults Found:
00471 - Control Module for Elect. Regulated Dampers (J250)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 127771 km
Time Indication: 0
Date: 2013.08.13
Time: 19:39:11
00317 - Rear Lid Control Module (J605)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 127771 km
Time Indication: 0
Date: 2013.08.13
Time: 19:39:12
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 145
Mileage: 132244 km
Time Indication: 0
Date: 2013.09.24
Time: 16:48:36
VCDS
Diagnostic Trouble Code Report
Page 2
02873 - Control Module for Back-Up Camera (J772)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 13
Reset counter: 208
Mileage: 132566 km
Time Indication: 0
Date: 2013.09.28
Time: 10:17:06
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 198
Mileage: 132660 km
Time Indication: 0
Date: 2013.09.30
Time: 09:06:28
00470 - Combination comfort Databus in Single Wire
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 208
Mileage: 133045 km
Time Indication: 0
Date: 2013.10.05
Time: 11:17:45
6C faults
Control Module Part Number: 4E0 910 441 HW: 4L0 907 441 A
Component and/or Version: J772__Rearview 0050
Software Coding: 1120003
Work Shop Code: WSC 02313 785 00200
8 Faults Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02283 - Video Connection to Output [End Unit]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 132555 km
Time Indication: 0
Date: 2013.09.28
Time: 08:50:05
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
VCDS
Page 2
02203 - Audio / Video Input 1
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 254
Reset counter: 208
Mileage: 127771 km
Time Indication: 0
Date: 2013.08.14
Time: 07:54:16
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Reset counter: 208
Mileage: 127771 km
Time Indication: 0
Date: 2013.08.14
Time: 07:54:16
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 26
Reset counter: 208
Mileage: 133045 km
Time Indication: 0
Date: 2013.10.05
Time: 11:17:46
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
VCDS
Page 3
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 208
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Thanks,
Louis
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 127771 km
Time Indication: 0
Date: 2013.08.13
Time: 19:39:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 127771 km
Time Indication: 0
Date: 2013.08.13
Time: 19:39:12
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 145
Mileage: 132244 km
Time Indication: 0
Date: 2013.09.24
Time: 16:48:36
VCDS
Page 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 208
Mileage: 132566 km
Time Indication: 0
Date: 2013.09.28
Time: 10:17:06
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 198
Mileage: 132660 km
Time Indication: 0
Date: 2013.09.30
Time: 09:06:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 208
Mileage: 133045 km
Time Indication: 0
Date: 2013.10.05
Time: 11:17:45
6C faults
8 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 132555 km
Time Indication: 0
Date: 2013.09.28
Time: 08:50:05
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
VCDS
Page 2
Freeze Frame:
Fault Priority: 4
Reset counter: 208
Mileage: 127771 km
Time Indication: 0
Date: 2013.08.14
Time: 07:54:16
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Reset counter: 208
Mileage: 127771 km
Time Indication: 0
Date: 2013.08.14
Time: 07:54:16
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 26
Reset counter: 208
Mileage: 133045 km
Time Indication: 0
Date: 2013.10.05
Time: 11:17:46
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
VCDS
Page 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 208
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
The camera cable center pin was missing . Mmi detects open = no camera = no switching . Made new connector and the camera came back on . Watch out for camera after market fakra connector - the center pin broke off .
I added rca connectors to be more reliable.
Cheers,
Louis
Cheers,
Louis
Cobra,
I couldn't sleep trying to figure this thing out - I kept reading the VCDS and this one gave me the clue - I actually went to the garage, turned on the lights and the soldering iron - Soldered - shrink tubed - tested - then I could sleep like a baby - 4AM.
I don't know what kind of damage I would get if I took the car to a dealer or an Audi shop to get this sorted out? Unimaginable!!!!
Cheers,
Louis
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 132555 km
Time Indication: 0
Date: 2013.09.28
Time: 08:50:05
Freeze Frame:
Term 15 On
Reverse ON
Cheers,
Louis
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 132555 km
Time Indication: 0
Date: 2013.09.28
Time: 08:50:05
Freeze Frame:
Term 15 On
Reverse ON
Funny thing is I was experiencing some frustrations with VCDS in controlling the ride height this weekend. Best thing I could have done was walk away and just like you at night walked back into the garage and just gave it another shot and pow!...all sorted!
Cheers,
Louis
[QUOTE=ltooz_a6_a8_q7;24495996]You may find the solutions for your cuts were "new" razors - or plastic surgery? hmmm... :-)
Yes, it's exactly what I'm trying unsuccessfully to perform... ;-(
hellonwheels33
32
04-16-2023 07:32 AM
snagitseven
A6 (C7 Platform) Discussion
212
07-01-2020 04:28 PM
