Sponsored by:
Sponsored by:
MMI - Interrmittent cut outs on radio etc.
Old 06-15-2012, 07:29 PM
  #11
Mike_k's Avatar
Originally Posted by UkiahA8L
I recently discovered a similar problem where my system would momentarily cut out from any source and then come back. I also discovered that a relay by the rear window subwoofer would "click" when this happened and i initially thought this to be the culprit but even after removing the sub fuse, the cut-outs continued. The AM/FM option also was unavailable but came back after performing a MMI reset. At this point I don't know if the problem has been fixed (I'll test drive tomorrow) but would still like any thoughts or recommendations in case the reset doesn't fix it.
This sound is indicating a break in your MOST (fiber optic) ring. I get it on hot days until the car cools down. I've added a Dension 500 and stock bluetooth setup so I assume it's one of my connections contracting ever so slightly with the warmer temperatures.
In your case it sounds like a component is failing and breaking the ring.
Old 08-01-2012, 06:07 AM
  #12
Joints's Avatar
Hello all,
I have the same problem in my wife's 2005 A8L. The MMI interface has had many spills etc. so I replaced it with a new unit directly from Audi. The problem still occurs. I just received my VCDS yesterday and ran a test of the MOST and it shows a fault for the "control head". Can anyone tell me where it is located in the car so I can check its connections?
Old 08-01-2012, 06:50 AM
  #13
Banned
JohnnyJ A6Q's Avatar
Default MMI CH
Originally Posted by Joints
Hello all,
Hello, it is on the right side behind glove box mounted to fire wall.
Old 08-01-2012, 12:26 PM
  #14
Joints's Avatar
Thanks.
Is this it?
Any way to reset it or diagnose it? Or should I just do what the dealer would and start replacing expensive parts?
Old 08-01-2012, 12:31 PM
  #15
Joints's Avatar
BTW, VCDS did show electrical and optical errors for the control head only.
Old 02-28-2013, 06:02 AM
  #16
John Clatworthy's Avatar
Default Intermittent radio, CD, SatNav, etc
Originally Posted by snapdragon
Pull out ashtray insert.
Remove screw that was hidden.
Remove ashtray housing.
Remove 2 screws that were hidden.
Where ashtray was, tug on a lower corner of aperture to pop wood up away from climate control, then other lower edge.
It should now be away from climate control which remains in situ.
Lift the centre console wood insert and buttons carefully and unhook from armrest end last.
(gear shifter remains in situ.
Turn centre console and unplug all connectors.
Carry into house or workshop.
Put on a soft towel.
Remove all the screws that hold in the MMI switches and park brake switch.
Start/Stop button module is held in with a brass rod, you need to drift it out with a thin screwdriver or needle type instrument.
The MMI controls should now lift out from above.
Once the module is out, you can clean it all up and clean in the car (mine was pretty ad underneath)
I sprayed isopropyl alcohol int0 my switches but was careful not to get any on the exposed switches in case t damaged the coating.
Good luck!
I have recently bought a 2009 plated A8 from a UK Audi dealer. Shortly after purchase I noticed the radio cutting out,or the phone or the Sat Nav audio. Sometimes the system would operate for well over an hour before the fault would appear on other occasions it would start immediately.
Fortunately the car is under warranty and so Audi were responsible for fixing it. I was told that any unit on the MOST would affect the whole audio system. There were no fault codes detected but after isolating the CD player in the glovebox the fault disappeared. A new one was installed and so far the fault has not replicated itself. Hope this helps.
Old 04-03-2013, 07:41 AM
  #17
ltooz_a6_a8_q7's Avatar
Default My 06 A8L's MMI turns itself ON/OFF this morning
Hello all,
I just got the car for over 1 week, I drove 6 hours without any problems. Last week, I update the MMI software from 1190 to 3360. This morning while driving to work, the MMI screen went black then turned back on with MMI welcome screen and played the radio as we set, none of the buttons on the MMI was functional - the radio was still playing - every few minutes - it shuts off and reboot again to the same radio channel and plays - No communication with buttons - Turned the engine off, took the key out, the MMI was still up and playing - Push the MMI button to turn off - nothing - push the button to close MMI on the dash - nothing.
Wait for it to reset itself - while on the welcome screen - push the MMI on/off button and it's off.
I think this is the reason why the dealer has not returned my call for updating the MMI software to newer version beyond 1190.
Again, I did it because I need to use AMI and camera retrofit. Well, I'll may as well update to 4610 since this doesn't work any how.
Cheers,
Louis
Old 04-03-2013, 06:20 PM
  #18
Default No communication between devices with MMI
Got the codes
Address 19: CAN Gateway
Control Module Part Number: 4E0 910 468 B
Component and/or Version: Gateway H11 0090
Software Coding: FCFE7BDD1B7104
Work Shop Code: WSC 02313
5 Faults Found
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 142
Mileage: 117259 km
Time Indication: 0
Date: 2013.02.11
Time: 09:42:00
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 117259 km
Time Indication: 0
Date: 2013.02.11
Time: 09:42:00
01301 - Control Module for Voice Recognition (J507)
Freeze Frame
Fault Priority: 3
Fault Frequency: 1
Reset counter: 142
Mileage: 118275 km
Time Indication: 0
Date: 2013.03.28
Time: 18:24:56
01304 - Radio
Freeze Frame
Fault Priority: 3
Fault Frequency: 26
Reset counter: 142
Mileage: 118275 km
Time Indication: 0
Date: 2013.03.28
Time: 18:28:58
02076 - Media Player Position 1 (R118)
Freeze Frame
Fault Priority: 3
Fault Frequency: 1
Reset counter: 142
Mileage: 118275 km
Time Indication: 0
Date: 2013.03.28
Time: 18:34:03
Clear the codes and everything is back.
Cheers,
Louis
Old 02-24-2014, 12:13 PM
  #19
Donnald Duck's Avatar
I have a similar problem' my 2006 A8 MMI has developed the fault where intermitently the speakers cut out every 3 seconds.
I have striped the unit down and cleaned it but the problem is still there.
Any clues??
Old 02-24-2014, 01:25 PM
  #20
mishar's Avatar
That sounds like Component Protection. Have you changed some module?
Quick Reply: MMI - Interrmittent cut outs on radio etc.
