MMI screen opens then closes
MMi screen open then closes also no lights on the MMI buttons.
I think the MMI controller is shot, any ideas?
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN44E37N011694 Mileage: 184870km-114872miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: Sporadic communication error 1000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 A HW: 4E0 907 552
Component: 5.2L V10/4V FSI ™0040
Revision: 5AH11--- Serial number: AUX3Z0FN710343
Coding: 01060009190F0160
Shop #: WSC 02116 444 59320
VCID: 20499647F30CD5214FB-8075
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 K HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI USA 0020
Revision: --H01--- Serial number: 0096529
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2B53716B8ACA0679EA9-807E
1 Fault Found:
049458 - Ride Level Control Module
U0132 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 184417 km
Time Indication: 0
Date: 2015.10.18
Time: 14:31:23
Freeze Frame:
RPM: 1376 /min
RPM: 1376 /min
RPM: 0 /min
(no units): 30.0
(no units): 20.0
Temperature: 17.0∞C
T.B. Angle: 0.0∞
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H46 0500
Coding: 0001627
Shop #: WSC 02313 000 00000
VCID: 24419A57E714C9012B3-8071
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0FN710343
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58B9FEA7EBDC5DE177B-800D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 0
Reset counter: 35
Mileage: 184432 km
Time Indication: 0
Date: 2015.10.18
Time: 19:45:18
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
2 Faults Found:
01877 - Belt Height Adjustment Button (E333); Down
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 15
Reset counter: 39
Mileage: 176916 km
Time Indication: 0
Date: 2015.08.24
Time: 16:50:48
01876 - Belt Height Adjustment Button (E333); Up
Freeze Frame:
Fault Priority: 4
Fault Frequency: 15
Reset counter: 39
Mileage: 176916 km
Time Indication: 0
Date: 2015.08.24
Time: 16:50:48
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 C HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 348JY067508344
Coding: 0000003
Shop #: WSC 00000 000 08192
VCID: 224D9C4FFD00C73159F-8077
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000024549
Subsystem 3 - Serial number: 0109.11.060000000100010007ˇ
Subsystem 4 - Serial number: 010007ˇ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000108997
Coding: 0041281
VCID: 1C31A2B7DF64F1C1933-8049
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133123
VCID: 3665501F41884B91857-8063
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H09 0700
Revision: 00000000
VCID: 275B8D5B562222190E1-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0129700
Shop #: WSC 00000 000 00000
VCID: 2C5172778FC40141E33-8079
Address 11: Engine II Labels: Redir Fail!
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0G00H6W
Coding: 0532707
VCID: 2645805F91283B11357-8073
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 3HPS4
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ˇÜ63
Subsystem 4 - Serial number: 000000ˇÜ63328RB401A29624CˇÜ63
Subsystem 5 - Serial number: 29624CˇÜ63428RB401A296AFWˇÜ63
Subsystem 6 - Serial number: 296AFWˇÜ63528RB4019F442DSˇÜ63
Subsystem 7 - Serial number: F442DSˇÜ63628RB4019F4391NˇÜ63
Subsystem 8 - Serial number: F4391NˇÜ63729RB401B82A8BYˇÜ63
Subsystem 9 - Serial number: 82A8BYˇÜ63829RB401B84435Kˇ
Subsystem 10 - Serial number: 84435Kˇ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenks‰ulenmodul H14 0040
Coding: 0012141
VCID: 65C7C753ACAEF009FCD-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 F HW: 4E0 920 951 F
Component: KOMBIINSTR. VDO H82 0530
Revision: D04 Serial number: AUDID3FN000225
Coding: 0048203
Shop #: WSC 45074 000 10485
VCID: 28598E679B3C2D6107B-807D
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06A30806C
Coding: F5D5DFFF707A0E
VCID: 6CD1B2774F44C141A33-8039
1 Fault Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 184417 km
Time Indication: 0
Date: 2015.10.18
Time: 14:31:23
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H44 0350
Revision: 00044000 Serial number: AUZ5ZBF3106212
VCID: 1839BEA72B5C9DE1B7B-804D
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0011210
VCID: 2A5D746F85301F7111F-807F
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 L
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381K4067509997
Shop #: WSC 02116 444 57843
VCID: 38795E274B9CBDE197B-806D
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000628900093
Coding: 0003477
VCID: 1D37AFB3C47EF8C964D-8048
2 Faults Found:
00410 - Pre-Selection Signal for Opening Sunroof
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 240
Mileage: 166744 km
Time Indication: 0
Date: 2015.06.12
Time: 13:14:00
02282 - Sunroof Drive; Obstruction Detection
000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 28
Mileage: 173948 km
Time Indication: 0
Date: 2015.08.03
Time: 17:46:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
Component: T¸rsteuer.FS BRM005 0180
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040611140222
Coding: 0048766
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
6 Faults Found:
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:27:39
02198 - Bulb for Tail Light 2; Left (M49)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:49:01
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:49:07
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:50:47
02200 - Communication Wire to Taillights
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 1
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 21:05:58
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 4
Mileage: 182722 km
Time Indication: 0
Date: 2015.10.04
Time: 17:02:22
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 C HW: 4E0 035 466
Component: BO_D3 H06 0310
Revision: 20S00002 Serial number: 03110060006402
Coding: 0000026
Subsystem 1 - Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Subsystem 2 - Serial number: 01010060003467
Subsystem 3 - Serial number: 0210.10.060000000100030059ˇ
Subsystem 4 - Serial number: 030059ˇ
2 Faults Found:
03029 - Subwoofer (R157)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Reset counter: 0
Mileage: 161999 km
Time Indication: 0
Date: 2015.05.09
Time: 20:35:01
Freeze Frame:
Voltage: 11.80 V
Temperature: 40.0∞C
Bin. Bits: 00000001
Voltage: 25.50 V
Temperature: -52.0∞C
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 0
Mileage: 184848 km
Time Indication: 0
Date: 2015.10.20
Time: 22:26:10
Freeze Frame:
Voltage: 12.10 V
Temperature: 32.0∞C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 38.0∞C
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000002827
Coding: 0010111
VCID: 1E35A8BFC978E3D17D7-804B
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T169R05
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
Component: T¸rsteuer.BF BRM005 0180
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000732
VCID: 1F4B95BBCE72EAD9761-804A
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 295F8B6380361469185-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
2 Faults Found:
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 173800 km
Time Indication: 0
Date: 2015.08.02
Time: 13:29:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 184424 km
Time Indication: 0
Date: 2015.10.18
Time: 14:31:23
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396K7067549837
Coding: 0000002
VCID: 2E55787FB9D87351CD7-807B
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000023865
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 311021L1CS
Coding: 34453039313531303541205641303331313032314C314353
Shop #: WSC 02116 444 103853
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 35
Reset counter: 255
Mileage: 161999 km
Time Indication: 0
Date: 2015.05.09
Time: 19:09:21
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 21
Reset counter: 255
Mileage: 161999 km
Time Indication: 0
Date: 2015.05.09
Time: 19:16:53
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 161999 km
Time Indication: 0
Date: 2015.05.09
Time: 19:17:03
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 184344 km
Time Indication: 0
Date: 2015.10.17
Time: 10:40:31
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 38
Mileage: 184627 km
Time Indication: 0
Date: 2015.10.20
Time: 02:01:24
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: T¸rsteuer.HL BRM005 0180
Coding: 0032364
1 Fault Found:
02124 - Exterior Door Handle Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 110
Mileage: 108448 km
Time Indication: 0
Date: 2014.06.08
Time: 22:49:36
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000700048151
Coding: 0232428
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 26
Mileage: 183983 km
Time Indication: 0
Date: 2015.10.14
Time: 06:34:59
Freeze Frame:
(no units): 0.0
Temperature: 13.0∞C
Error Code: 2
Pressure: 2.55 bar
Pressure: 2.62 bar
Pressure: 2.65 bar
Pressure: 2.67 bar
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000611110279
Shop #: WSC 12336 024 394758
VCID: 34616A1757F45981BB3-8061
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6910XT
Coding: 1121402
VCID: 5CB1E2B79FE4B1C1533-8009
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: T¸rsteuer.HR BRM005 0180
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730629706563
Coding: 0221208
VCID: 2343994BE21ACE39529-8076
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H20 0950
Revision: 00000000 Serial number: 00000005035539
Coding: 0010900
Shop #: WSC 02116 444 53299
VCID: 25478753EC2E30093CD-8070
End-------------------------(Elapsed Time: 04:29)--------------------------
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 184417 km
Time Indication: 0
Date: 2015.10.18
Time: 14:31:23
Freeze Frame:
RPM: 1376 /min
RPM: 1376 /min
RPM: 0 /min
(no units): 30.0
(no units): 20.0
Temperature: 17.0∞C
T.B. Angle: 0.0∞
Coding: 0001627
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 35
Mileage: 184432 km
Time Indication: 0
Date: 2015.10.18
Time: 19:45:18
Coding: 4071520
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 15
Reset counter: 39
Mileage: 176916 km
Time Indication: 0
Date: 2015.08.24
Time: 16:50:48
Freeze Frame:
Fault Priority: 4
Fault Frequency: 15
Reset counter: 39
Mileage: 176916 km
Time Indication: 0
Date: 2015.08.24
Time: 16:50:48
Coding: 0000003
Coding: 0041281
Coding: 0133123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Revision: 00000000
Coding: 0532707
Coding: 0012141
Coding: 0048203
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 184417 km
Time Indication: 0
Date: 2015.10.18
Time: 14:31:23
Coding: 0011210
Coding: 4071530
Coding: 0003477
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 240
Mileage: 166744 km
Time Indication: 0
Date: 2015.06.12
Time: 13:14:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 28
Mileage: 173948 km
Time Indication: 0
Date: 2015.08.03
Time: 17:46:00
Coding: 0032364
Coding: 0048766
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:27:39
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:49:01
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:49:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:50:47
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 1
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 21:05:58
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 4
Mileage: 182722 km
Time Indication: 0
Date: 2015.10.04
Time: 17:02:22
Coding: 0000026
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 0
Mileage: 161999 km
Time Indication: 0
Date: 2015.05.09
Time: 20:35:01
Freeze Frame:
Voltage: 11.80 V
Temperature: 40.0∞C
Bin. Bits: 00000001
Voltage: 25.50 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 0
Mileage: 184848 km
Time Indication: 0
Date: 2015.10.20
Time: 22:26:10
Freeze Frame:
Voltage: 12.10 V
Temperature: 32.0∞C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 38.0∞C
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000732
Coding: 0000018
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 173800 km
Time Indication: 0
Date: 2015.08.02
Time: 13:29:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 184424 km
Time Indication: 0
Date: 2015.10.18
Time: 14:31:23
Coding: 0000002
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 35
Reset counter: 255
Mileage: 161999 km
Time Indication: 0
Date: 2015.05.09
Time: 19:09:21
Freeze Frame:
Fault Priority: 7
Fault Frequency: 21
Reset counter: 255
Mileage: 161999 km
Time Indication: 0
Date: 2015.05.09
Time: 19:16:53
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 161999 km
Time Indication: 0
Date: 2015.05.09
Time: 19:17:03
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 184344 km
Time Indication: 0
Date: 2015.10.17
Time: 10:40:31
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 38
Mileage: 184627 km
Time Indication: 0
Date: 2015.10.20
Time: 02:01:24
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 110
Mileage: 108448 km
Time Indication: 0
Date: 2014.06.08
Time: 22:49:36
Coding: 0232428
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 26
Mileage: 183983 km
Time Indication: 0
Date: 2015.10.14
Time: 06:34:59
Freeze Frame:
(no units): 0.0
Temperature: 13.0∞C
Error Code: 2
Pressure: 2.55 bar
Pressure: 2.62 bar
Pressure: 2.65 bar
Pressure: 2.67 bar
Coding: 1121402
Coding: 0032364
Coding: 0221208
Coding: 0010900
Check for Pepsi Syndrome--spilled soda, coffee, etc. on MMI controls.
Also, check for food bits, threads, etc. around MMI buttons--any stuck or jammed buttons can lead to screen dance.
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
0E-Media Player 1 OK OK
1E-Media Player 2 OK OK
77-Telephone OK OK
47-Sound System OK OK
67-Voice Control OK OK
56-Radio OK OK
37-Navigation OK OK
0F-Digital Radio(SAT) OK OK
77-Telephone OK OK
56-Radio OK OK
37-Navigation OK OK
I should mention that I don't eat in the car so nothing was spilled. There are no visible leaks anywhere When the screen comes up, the Navigation shows but the screen closes and the buttons don't light up. Tried the MMI reset but it seems unresponsive. I will check fuses again. I left the car off the battery overnight. I also swapped battery's a month or two ago.
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Component: 5.2L V10/4V FSI ª0040
5 Faults Found:
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 001 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 192161 km
Time Indication: 0
Date: 2015.12.18
Time: 20:09:04
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 26.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.938 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 194606 km
Time Indication: 0
Date: 2016.01.09
Time: 00:00:59
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 21.0°C
Voltage: 11.811 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005161 - Circuit for Brake Vacuum Pump
P1429 - 004 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 194606 km
Time Indication: 0
Freeze Frame:
RPM: 771 /min
Load: 68.2 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 22.0°C
Voltage: 10.668 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 194606 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 23.0°C
Voltage: 11.938 V
Readiness: 0110 1101
Coding: 0001627
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Cannot be reached
Cannot be reached
Cannot be reached
2 Faults Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 194606 km
Time Indication: 0
Date: 2016.01.09
Time: 00:00:59
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 21.0°C
Voltage: 11.811 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Cannot be reached
Cannot be reached
Coding: 0003477
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 203
Mileage: 194404 km
Time Indication: 0
Date: 2016.01.08
Time: 06:22:00
Coding: 0048830
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:27:39
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:49:01
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:49:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:50:47
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 166
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 21:05:58
02167 - Control Module for Tilt-Sensing Alarm (J529)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 169
Mileage: 192081 km
Time Indication: 0
Date: 2015.12.18
Time: 15:45:09
Cannot be reached
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 1121402
1 Fault Found:
00778 - Steering Angle Sensor (G85)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 194606 km
Time Indication: 0
Date: 2016.01.09
Time: 01:29:51
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Cannot be reached
End-------------------------(Elapsed Time: 04:48)--------------------------
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 192161 km
Time Indication: 0
Date: 2015.12.18
Time: 20:09:04
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 26.0°C
Voltage: 11.938 V
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 194606 km
Time Indication: 0
Date: 2016.01.09
Time: 00:00:59
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 21.0°C
Voltage: 11.811 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 194606 km
Time Indication: 0
Freeze Frame:
RPM: 771 /min
Load: 68.2 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 22.0°C
Voltage: 10.668 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 194606 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 23.0°C
Voltage: 11.938 V
Coding: 0001627
1 Fault Found:
000 - -
Cannot be reached
Cannot be reached
Cannot be reached
2 Faults Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 194606 km
Time Indication: 0
Date: 2016.01.09
Time: 00:00:59
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 21.0°C
Voltage: 11.811 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Cannot be reached
Cannot be reached
Coding: 0003477
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 203
Mileage: 194404 km
Time Indication: 0
Date: 2016.01.08
Time: 06:22:00
Coding: 0048830
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:27:39
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:49:01
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:49:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 20:50:47
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 166
Mileage: 158054 km
Time Indication: 0
Date: 2015.04.13
Time: 21:05:58
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 169
Mileage: 192081 km
Time Indication: 0
Date: 2015.12.18
Time: 15:45:09
Cannot be reached
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 1121402
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 194606 km
Time Indication: 0
Date: 2016.01.09
Time: 01:29:51
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Cannot be reached
So you are getting Nav on your screen ?
As said above the most common fault is a stuck button.
I would double check all fuses.
Double check buttons.
Don't know what happens if you unplug the centre console but may be worth a try.
The mmi retract button on the dash working ?
Did have ignition on with this latest scan?
