MMI screen won't pop up...Help !!
#11
There is actually an easy way to install a switch so that you can keep the screen open all the time. This took me less than an hour to do. Check this thread by dvs dave to find out how.
https://www.audiworld.com/forums/a8-...sable-2896700/
#14
Ya, Headed to CT in July so i will wait and hope the mechanism holds up. Is there a fuse that disconnects the the motor????? I have a VAG-COM cable but there is no error code to deal with. The radio stays on after the ignition is off, so I push the volume button til the screen goes off. 2 weeks to CT. In the stuck up position i can still use the backup cam, radio, MMI controls and nav system.
#15
I pulled off the trim around the MMI and was surprised to see a thin string like a window blind. This is how the screen is moved from hidden to up position. I think the string may have gotten bound up in there somewhere. I was not brave enough to pull it apart. The car is still under warranty so I will get to a dealer. Problem is the dealers are in Charleston, SC and Wilmington, NC. both about 90 miles from my home. Now that is stuck in the up position I will wait til I get to CT where I bought the car. It has a recall to on the cooling system. Thanks
#17
MMI Will not pop up as well. all my components have power i can eject vavigation cd in trunk. My glove box cd player i can eject and load cds. Help please
#18
Likely the gears need replacing.
Dozens of threads on this already.
This youtube video shows an interesting hack to hold/jam it permanently open/up with some Perspex if you don't want to replace the gears.
mjaiello
Q5/SQ5 MKI (8R) Discussion
34
05-12-2021 05:46 PM
zinctheracer
RS4 (B7 Platform) Discussion
11
06-16-2009 05:27 PM
