Sponsored by:
Sponsored by:
MMI Update issue and VAG Com results help
Old 01-07-2013, 02:43 PM
  #11
maximumsp's Avatar
Originally Posted by JohnnyJ A6Q
did you not state that you were using the second from last SW update before you edited your post today, that {2nd from last} would be 4140, now Mishar I may be wrong, but I know one can go from xxxx to 4610, buy not sure on the 0600, as when I did my 04 I went from 2750 to 3360, now on my 05 I completely flashed from Euro 2120 iirc to US 4610, but I swear the OP said 2nd from last, which is 4140 and is not a repair kit and therefore will not allow from 0600 forward.
Yes, I did write that originally but I was wrong and misread my own MMI. I am still a newbie. Sorry for the confusion.
Old 01-07-2013, 03:38 PM
  #12
Banned
JohnnyJ A6Q's Avatar
Default Please explain
Are you saying you had seen 4610 on your MMI, it does not make since, what did you misread ?
also the three red "X" boxes are they the same as the three pictures you attached, as there are only three pics in your post, and the last one shows you at 0600 sw level.
ALSO did you update the NAV before MMI, make sure that your Navigation software is at least v.5 or higher. Don't do the MMI update if your navi version is lower. Update the navi first.
Old 01-07-2013, 03:56 PM
  #13
mishar's Avatar
Thanks for the response Mishar but huh? What? I dont understand
In your original mail you didn't say which update you are trying to use, you have three broken pictures and one bad link. You didn't say if anything was done prior to that update attempt, like replacing some module that might have active Component Protection or wrong software on it... So help us to help you, if we can.
Old 01-07-2013, 04:39 PM
  #14
Banned
Default Now you have a 2004 A8 and therefore do not have bluetooth, So that is not the
Problem, are you 100% sure on the 4610, as your picture shows the message of MMI (V1.1.a.11.7.18.f.2). Use other CD, which leads to it not being a 4610 update set
From http://forums.quattroworld.com/c6a6/threads/689.phtml
Posted by: haloguy628 (13625) on 2011-12-10 23:52:23
Since you are going to 4.6.10 you don't need the 3.3.60 update. The 3.3.60 is only required when updating to 4.4.10.
Caution: Read the TSB on the Bluetooth update/fix that has to be done before the MMI update if you have MY 2006 or 2007 car. •Audizine 2007 S6 MMI Update
Tried it this week-end, something's wrong
Posted by: gabster (13754) on 2011-12-26 09:52:58
Updating the phone went fine, Handyvorb2 showed OK after running the first CD; but for some reason, when running the second CD, it gives me an error saying: "Incomplete metadata for EEPROM-Update of MMI (V1.1.a.11.7.18.f.2). Use other CD". WTF? What am I missing here?
That's the same message...
Posted by: haloguy628 (13625) on 2011-12-26 14:55:06
I was getting with 3.3.60. That message gets kicked out when the checksum does not add up and it thinks that you are using the wrong update. It prevents the update from running in order not to brick the MMI.
Been there, done that....
Posted by: haloguy628 (13625) on 2011-12-12 01:16:04
I updated directly from 2.7.50 to 4.6.10. I have the 3.3.60 CD but could not use it because I was getting error. It's a long story but in short there is an error in line of code on some 06 and 07 cars giving wrong model of the MMI H/U. The checksum then prevents the update to 3.3.60. or 4.1.40. (You get error "Uncomplete Metadata for EEPROM-Update for MMI" in german when trying to update).
So I did search high and low and found some posts from Audi master technicians stating that the newest NA update 4.6.10 did fix all of the problems with 4.1.40 and that the 3.3.60 is not needed anymore.
However be aware that the 4.6.10 comes with two CD's. The first one is for checking and if needed repairing of the Bluetooth hands free module. You need to run the CD-1 first.
If you don't, and the SW and FW versions of the module are mismatched you will fry the BT module. The description is in the TSB. Pretty simple procedure:
Check the FW and SW of the phone preparation module.
Hold down SETUP and RETURN until you get to the service screen. Scroll down and click on HANDYVORB2. Check the HW Index and the SW Index.
If you have HW Index H16 with SW Index 0700 you need to first run FW update of the phone preparation module.
Once the FW is updated run the CD-1 again to update the SW of the phone prep module.
The update is on the Disk-1 of the 4610 update set (P/N 4F0 998
961).
Next make sure that your Navigation software is at least v.5 or higher. Don't do the MMI update if your navi version is lower. Update the navi first. (You can get copy of 2010 year update on the net).
Once that is done, you can go ahead and use the CD-2 for updating rest of the MMI modules to 4.6.10. Just hook the car to charger or have the engine running, and do not use anything while it's updating
Old 01-07-2013, 05:25 PM
  #15
hanilanzi's Avatar
there must be something else going on with his MMI.
when we tried updating it he didnt have Handyvorb2 anywhere,
and i updated my A8 (same year as Max's and it updated with no problems)
couple weeks earlier so not sure what is going on with it.
Max, copy paste your vagcom report here, because your link to google
document doesn't work!
Old 01-07-2013, 05:26 PM
  #16
hanilanzi's Avatar
actually i have a copy of it here...
here it is guys...fire away!
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Saturday,29,December,2012,15:42:22:08940
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 76
VIN: WAUML44E34N001901 Mileage: 103710km/64442miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 1010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 1010
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0050
Revision: 00000000 Serial number: AUX3Z0C3513329
Coding: 0007773
Shop #: WSC 02353 785 00200
VCID: 1F479B0DCE9F30E038F
3 Faults Found:
17983 - Right Engine Mount Solenoid Valve (N145)
P1575 - 001 - Short to Plus
16586 - Injector: Cylinder 2 (N31)
P0202 - 004 - Circuit Malfunction - Intermittent
16804 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - MIL ON
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0060
Coding: 0000002
VCID: 244D94E1E7F9133865D
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Freeze Frame:
RPM: 1568 /min
RPM: 1600 /min
RPM: 0 /min
(no units): 30.0
(no units): 13.0
Temperature: 3.0°C
T.B. Angle: 0.0°
Voltage: 11.20 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 01234 000 00000
VCID: 21439DF5F8EB06100EB
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H02 0120
Revision: 01203502 Serial number: AUX3Z0C3513329
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: D8B570116B3107D8B95
Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00172 - Key 2 not learned
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 8
Reset counter: 86
Mileage: 102832 km
Time Indication: 0
Date: 2012.12.04
Time: 21:54:36
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 4
Reset counter: 81
Mileage: 103168 km
Time Indication: 0
Date: 2012.12.19
Time: 16:56:00
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 81
Mileage: 103168 km
Time Indication: 0
Date: 2012.12.19
Time: 17:56:14
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 02313 785 00200
VCID: 234F97FDE2F714001C7
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 81
Mileage: 103180 km
Time Indication: 0
Date: 2012.12.17
Time: 13:14:55
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 346IQ047514236
Coding: 0000003
Shop #: WSC 03107 444 85904
VCID: 2F676BCDBE3FA06088F
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
2 Faults Found:
02244 - Button in Control Head is Stuck
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 39
Mileage: 103369 km
Time Indication: 0
Date: 2012.12.22
Time: 20:08:59
Freeze Frame:
Bin. Bits: 00010000
Bin. Bits: 0000000
Bin. Bits: 000
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 15:02:39
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 772 HW: 4E0 820 043 B
Component: Sitzluefter FS H05 010
Revision: 00000014 Serial number: 00000000015179
Shop #: WSC 00000 000 00000
VCID: E3CF57FD2277D400DC7
Part No: 4E0 910 772
Component: Sitzluefter BFS H05 010
1 Fault Found:
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 73
Reset counter: 92
Mileage: 101795 km
Time Indication: 0
Date: 2003.03.26
Time: 04:48:17
Freeze Frame:
Voltage: 13.80 V
(no units): 85.0
(no units): 255.0
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A517AD985DDC5485F1
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
1 Fault Found:
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 13:06:04
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Serial number: AUZ5ZBC1013765
VCID: 1933B515D0BB5ED0C6B
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 13:17:19
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 15:03:56
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 A
Component: Airbag 8.4E+ H08 0820
Coding: 0530707
4 Faults Found:
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
001 - Upper Limit Exceeded - Intermittent
01220 - Rear Side Airbag Igniter; Passenger Side (N202)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01219 - Rear Side Airbag Igniter; Driver Side (N201)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H09 0030
Coding: 0012241
VCID: E5CB49E52C43AA30323
Component: Lenkradmodul H02 0050
8 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 81
Mileage: 102762 km
Time Indication: 0
Date: 2012.11.26
Time: 13:12:00
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 81
Mileage: 102762 km
Time Indication: 0
Date: 2012.11.26
Time: 13:12:00
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 81
Mileage: 102762 km
Time Indication: 0
Date: 2003.02.27
Time: 00:02:59
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 81
Mileage: 102762 km
Time Indication: 0
Date: 2003.02.27
Time: 00:07:43
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 13:15:13
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 15:04:02
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 14
Reset counter: 81
Mileage: 1048575 km
Time Indication: 0
Date: 2127.15.31
Time: 31:63:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 81
Mileage: 1048575 km
Time Indication: 0
Date: 2127.15.31
Time: 31:63:02
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H42 0060
Revision: D07 Serial number: AUDID3C3000961
Coding: 0000223
Shop #: WSC 05152 444 64193
VCID: DCBD6C011F09EBF89DD
2 Faults Found:
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 13:06:41
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Mileage: 79823 km
Time Indication: 0
Date: 2009.12.07
Time: 04:29:12
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H06 0020
Revision: 06 Serial number: 5000341003F601
Coding: FCFE7BDD1B2104
Shop #: WSC 08307 444 70066
VCID: 26498EE991C5E1287B9
4 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 102945 km
Time Indication: 0
Date: 2012.12.06
Time: 20:49:38
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 102945 km
Time Indication: 0
Date: 2012.12.06
Time: 20:49:38
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 103183 km
Time Indication: 0
Date: 2012.12.19
Time: 16:59:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 103183 km
Time Indication: 0
Date: 2012.12.19
Time: 17:56:13
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 86
Mileage: 102832 km
Time Indication: 0
Date: 2012.12.04
Time: 21:54:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 81
Mileage: 103168 km
Time Indication: 0
Date: 2012.12.19
Time: 16:56:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 81
Mileage: 103168 km
Time Indication: 0
Date: 2012.12.19
Time: 17:56:14
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 254B89E5ECC3EA30723
5 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 230
Reset counter: 100
Mileage: 84067 km
Time Indication: 0
Date: 2011.01.27
Time: 08:11:47
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 13:06:19
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 81
Mileage: 100712 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:12
01598 - Drive Battery Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 81
Mileage: 0 km
Time Indication: 0
01400 - Suspension Level Control
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 103532 km
Time Indication: 0
Date: 2012.12.25
Time: 19:58:13
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H06 0060
Coding: 4071522
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 103180 km
Time Indication: 0
Date: 2012.12.17
Time: 13:06:57
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H41 0570
Revision: 00000000 Serial number: 355DG037504071
VCID: 356B59A55C639AB0C23
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 13:12:32
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 13:08:50
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0080
Serial number: 00000308600030
Coding: 0003989
VCID: 1D3BA105C49322F02A3
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 81
Mileage: 103180 km
Time Indication: 0
Date: 2012.12.19
Time: 17:56:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 81
Mileage: 103180 km
Time Indication: 0
Date: 2012.12.19
Time: 17:01:00
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 67
Mileage: 102956 km
Time Indication: 0
Date: 2012.12.06
Time: 21:04:00
00447 - Function Limitation due to Over-Voltage
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 81
Mileage: 103180 km
Time Indication: 0
Date: 2012.12.17
Time: 15:37:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM004 0080
Coding: 0028196
VCID: DEB966090915F9E8F39
5 Faults Found:
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 81
Mileage: 103168 km
Time Indication: 0
Date: 2012.12.17
Time: 13:17:14
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 81
Mileage: 0 km
Time Indication: 0
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 81
Mileage: 103168 km
Time Indication: 0
Date: 2012.12.19
Time: 17:07:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 81
Mileage: 103168 km
Time Indication: 0
Date: 2012.12.19
Time: 17:07:52
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 81
Mileage: 103168 km
Time Indication: 0
Date: 2012.12.19
Time: 17:56:40
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040304100126
Coding: 0065086
VCID: 275783ED96CFF82040F
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H02 0020
8 Faults Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 60
Mileage: 34303 km
Time Indication: 0
Date: 2006.03.17
Time: 14:37:23
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Reset counter: 59
Mileage: 82428 km
Time Indication: 0
Date: 2010.05.09
Time: 08:22:01
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 59
Mileage: 82428 km
Time Indication: 0
Date: 2010.05.09
Time: 08:22:01
01503 - Bulb for 3rd Brake Light (M25)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 19
Reset counter: 85
Mileage: 103183 km
Time Indication: 0
Date: 2012.12.18
Time: 18:06:04
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Priority: 3
Reset counter: 81
Mileage: 100681 km
Time Indication: 0
Date: 2003.08.17
Time: 19:05:40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 103183 km
Time Indication: 0
Date: 2012.12.19
Time: 17:00:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 81
Mileage: 103183 km
Time Indication: 0
Date: 2012.12.19
Time: 17:56:18
02198 - Bulb for Tail Light 2; Left (M49)
Freeze Frame:
Fault Priority: 3
Reset counter: 81
Mileage: 100712 km
Time Indication: 0
Date: 2003.02.27
Time: 00:53:07
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 H HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0370
Revision: Dev_D01 Serial number: 00000000003766
Coding: 0000018
VCID: 224192F9FDED1D08171
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 13:09:50
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 81
Mileage: 103182 km
Time Indication: 0
Date: 2012.12.17
Time: 13:07:06
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 101910 km
Time Indication: 0
Date: 2012.10.14
Time: 15:28:26
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000013385
Coding: 0010111
VCID: DDBB61050413E2F0EA3
3 Faults Found:
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 81
Mileage: 103180 km
Time Indication: 0
Date: 2012.12.17
Time: 15:04:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 81
Mileage: 103180 km
Time Indication: 0
Date: 2012.12.17
Time: 13:07:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 103180 km
Time Indication: 0
Old 01-07-2013, 06:38 PM
  #17
Banned
Default In order to help you
I need answers to my questions.
Old 01-07-2013, 07:27 PM
  #18
subit0's Avatar
Default No BT.
If the OP was coming from MMI 0600, then his vehicle is likely a 2004 MY, in which case there is no Bluetooth module, but instead has Onstar. Subsequently, CD1 of 4610 wouldn't do anything. That said, I would have assumed that 4610 CD2 would just install normally.
Have you tried upgrading to 3360?
Old 01-07-2013, 09:03 PM
  #19
mishar's Avatar
Everything malfunctioned almost at the same time. Not possible. What went wrong on December 17th?
Old 01-08-2013, 08:01 AM
  #20
hanilanzi's Avatar
no clue.
i just pulled this for Max on Dec 29th i think.
i haven't had a chance to look at all of the errors but it seems
like there are a lot!
subit0,
we've tried CD1 and no dice.
2nd CD just told us about EPROM error.
when i did my 2004 A8 couple weeks earlier it was a walk in the park.
I don't have 3360 CDs, only 4610.
Quick Reply: MMI Update issue and VAG Com results help
