MMI version - please help
Just picked up my 2006 A8 from the dealer. What version of the MMI software am I running? Can I upgrade the version I have now?
Thanks for any help.
Since your location shows NY, as mishar pointed out your MMI is running the North American software version 1190
North America versions:
0600 (0.6.00) -
1190 (1.1.90) -
2750 (2.7.50) - version 2750 and below have to be upgraded to 3360 before upgrading to a higher version
3310 (3.3.10) -
3360 (3.3.60) - {Update CD p/n 4F0 906 961AB}
4140 (4.1.40) - {Update CD p/n 4L0 906 961 H}
4610 (4.6.10) - {Update CD set p/n 4F0 998 961}"
"European / ROW (Rest of the World) versions:
0890 (0.8.90) -
1190 (1.1.90) -
1200 (1.2.00) -
2120 (2.1.20) - {Update CD p/n 4E0 906 961 L}
3460 (3.4.60) - {Update CD p/n 4E0 906 961 T}
4220 (4.2.20) - {Update CD p/n 4E0 906 961 AA}
5150 (5.1.50) - {Update CD p/n 4F0 906 961 AB}
5170 (5.1.79) -
5570 (5.5.70) - {Update CD set p/n 4L0 998 961 (A6/A8/Q7) or p/n 8K0 998 961 (A4 B8/A5)}
0600 (0.6.00) -
1190 (1.1.90) -
3310 (3.3.10) -
0890 (0.8.90) -
1190 (1.1.90) -
1200 (1.2.00) -
5170 (5.1.79) -
If you obtain the correct CD sets, you can run this yourself providing you follow the procedure to the letter.
Make sure you have a battery charger which gives at least 5amp charge, connected throughout - connection must be to the + terminal of the battery and to the ground post which is visible above the left hand end of the battery. Do not connect anything directly to the - (negative) terminal of the battery itself.
For the upgrade - there are many recent posts including the correct procedure - save to say - make sure everything other than the MMI is off and do not even open the door - keep the door open with the latch closed to turn off ALL ancillary items and do not operate anything electrical.
Allow a good couple of hours for the upgrade and remove all additional CD's from the changer before starting.
ramx2
02-08-2013 12:25 AM
joedirt1
01-07-2010 12:57 PM
