my A8L was on a flat bed today-long and sad
#12
The software will actually say which general area has a leak based on sensor values. Then it's time for good old fashioned automotive diagnosis and repair. Visual inspections, tugging on lines looking for crack and if all else fails, you disconnect a line and pump in air and listen for the leak. You will be able to find it that way.
#13
Just replaced the passenger side fuel pump and the car is working like new but there were different symptoms. In our case, you would start the car and let it idle and every time after 30 seconds, the car would just stall out and die. That is unless you would put your foot down and kicked the rpm's up over at least 3,500 rpm
ChooChooNongNongHead
01-20-2007 11:55 AM
