My First VCDS report!!! Please explain some of my questions.
I ran my first VCDS report this evening. I need further clarification on some of these malfunctions and if they are accurate.
Thursday,15,February,2018,20:59:08:61955
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
Ross-Tech: Home
VIN: WAURVAFAXAN005884 License Plate:
Chassis Type: FA (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 19 1E 28 34 36 37
38 3C 42 46 47 4F 52 53 55 56 5C 61 62 65 67 6C 72 76 77
VIN: WAURVAFAXAN005884 Mileage: 137560km-85475miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010 - Is this due to the car not running??
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010 - Is this due to the car not running?
06-Seat Mem. Pass -- Status: Malfunction 0010 - Is this due to the car not running?
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010 - Is this due to the car not running?
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010 - Is this due to the car not running?
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010 - Is this due to the car not running?
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010 - Is this due to the car not running?
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010 - Is this due to the car not running?
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010 - Is this due to the car not running?
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010 - Is this due to the car not running?
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010 - Is this due to the car not running?
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BVJ) Labels:. 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 P HW: 4E1 907 560
Component: 4.2l V8/4V 0030
Revision: 71H28--- Serial number: AUX3Z0J0771648
Coding: 01060009190F0220
Shop #: WSC 02313 785 00200
VCID: 2F3BEED7EB126C4FC1F-807A
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 137242 km
Time Indication: 0
Date: 2018.02.02
Time: 17:36:48
Freeze Frame:
RPM: 689 /min
Load: 43.1 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 1.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.462 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 137242 km
Time Indication: 0
Date: 2018.02.02
Time: 17:36:48
Freeze Frame:
RPM: 689 /min
Load: 43.1 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 1.0°C
Voltage: 13.462 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E2 910 156 D HW: 09L 927 156 A
Component: AG6 09L 4,2 FSI USA 0020
Revision: --H01--- Serial number: 4547248
Coding: 0000002
VCID: 25170CFFB9EE261F3B3-8070
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 CP
Component: ESP 5.7 allrad H50 0540
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2A0DFFC3D0F00967161-807E
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0J0771648
Coding: 0410624
VCID: 58E9750BBE1C4BF7705-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 0
Reset counter: 214
Mileage: 136544 km
Time Indication: 0
Date: 2017.10.27
Time: 14:23:02
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 233
Mileage: 137024 km
Time Indication: 0
Date: 2017.12.26
Time: 10:32:02
00193 - Rear Right Door Handle Touch Sensor (G418)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 12
Reset counter: 207
Mileage: 137040 km
Time Indication: 0
Date: 2018.01.27
Time: 20:28:12
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 241111FBB2D4DF172CD-8070
1 Fault Found:
02317 - Potentiometer for Lumbar Height / Massage (G423)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 211
Mileage: 120568 km
Time Indication: 0
Date: 2016.12.02
Time: 19:20:26
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348AU0A7531961
Coding: 0000003
VCID: 3333E2A7073A48AFA57-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000088928
Subsystem 3 - Serial number: 0122.01.100000000100010016ÿ
Subsystem 4 - Serial number: 010016ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000170014
Coding: 0102737
VCID: 1C61291B8AA4E7D794D-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO08012010065A000000000068ÿ†89
Subsystem 5 - Serial number: 000068ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO07012010065A00000000
Subsystem 7 - Serial number: 65A000000000163ÿ
3 Faults Found:
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 250
Mileage: 130781 km
Time Indication: 0
Date: 2017.06.20
Time: 06:29:45
Freeze Frame:
Voltage: 13.30 V
00065 - Rear Left Footwell Heater (Z42)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 51
Reset counter: 226
Mileage: 136899 km
Time Indication: 0
Date: 2017.11.30
Time: 22:53:50
Freeze Frame:
Voltage: 14.20 V
00710 - Defroster Flap Positioning Motor (V107)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 241
Mileage: 137055 km
Time Indication: 0
Date: 2018.01.31
Time: 20:14:59
Freeze Frame:
Voltage: 13.70 V
Temperature: 16.0°C
(no units): 64.0
(no units): 66.0
Temperature: 2.0°C
Raw, Form. N/A: 000 000 000
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0133123
VCID: 3829D58B1E5CABF7905-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150573
Shop #: WSC 02313
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 020000
Shop #: WSC 02399 823 56573
VCID: 2B03FAC7D30A106FED7-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7J0541479
Coding: 0000100
VCID: 313FE8AFFD267ABFD7B-8064
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 28
Mileage: 133504 km
Time Indication: 0
Date: 2017.08.25
Time: 11:01:06
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0011218
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 F HW: 4E0 959 655 L
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CV00052KU
Coding: 0532707
VCID: 290F00CFD5F6027F1FB-807C
Subsystem 1 - Part No: 4E0 910 339 C
Component: BF-Gewichtsens. H02 0040
Subsystem 2 - Serial number: 03K6X
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB4053603A6Bÿ†63
Subsystem 5 - Serial number: 603A6Bÿ†63428RB40536038DHÿ†63
Subsystem 6 - Serial number: 6038DHÿ†63528RB4053603603ÿ†63
Subsystem 7 - Serial number: 603603ÿ†63628RB4053603615ÿ†63
Subsystem 8 - Serial number: 603615ÿ†63729RB40490F987Zÿ†63
Subsystem 9 - Serial number: 0F987Zÿ†63829RB40490F9C4.ÿ
Subsystem 10 - Serial number: 0F9C4.ÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0530
Revision: 00H06000 Serial number: 90055092050109
Coding: 0032351
VCID: 26150BF3C4E82D07329-8072
Component: E0221 H01 0030
1 Fault Found:
02795 - Steering Wheel Vibration Motor (V331)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 247
Mileage: 137491 km
Time Indication: 0
Date: 2018.02.12
Time: 16:35:11
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 981 D HW: 4E0 920 981 D
Component: KOMBIINSTR. VDO H86 0640
Revision: D06 Serial number: AUDID3J1100498
Coding: 0048283
Shop #: WSC 49126 001 1048576
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4E0 907 468 H
Component: J533__Gateway H06 0071
Revision: 00H06000 Serial number: 0300J09B198006
Coding: F5F5DF7F777A0E00
VCID: 2D07F4DFE11E1E5FF33-8078
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H48 0390
Revision: 00048004 Serial number: AUZ5ZBJ8938404
Shop #: WSC 00000 000 00000
VCID: 1A6D2F03809099E7861-804E
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000088719
Coding: 0000000
VCID: 619F58EFED468A3F07B-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 K HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 4590
Coding: 0015510
VCID: 2B03FAC7DF0A106FED7-807E
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
1 Fault Found:
01451 - Driver's Seat Fore/Aft and Height Adjust Switch (E61); Up
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 226
Mileage: 137028 km
Time Indication: 0
Date: 2017.12.04
Time: 12:25:24
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H52 1100
Revision: 00000000 Serial number: 395K3097533775
Shop #: WSC 01104 444 53357
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000000000000
Coding: 0003477
VCID: 1D67241F91BEEEDF633-8048
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0040
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0000008
VCID: 2E05F3D3EC186547CA9-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H01 0040
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F03.12.0900H010003C911130ÿ
Subsystem 4 - Serial number: 911130ÿ
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
VCID: 20191DEBA6CCC337485-8074
1 Fault Found:
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 0
Reset counter: 235
Mileage: 137232 km
Time Indication: 0
Date: 2018.02.02
Time: 17:40:30
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H11 0040
Revision: 00400011 Serial number: W041001140156
Coding: 0048686
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000110013
Coding: 0000026
VCID: 2C01F9DBDA041757E4D-8078
1 Fault Found:
00871 - Bass Speaker Front Right (R23)
Freeze Frame:
Fault Status: 00111011
Fault Priority: 5
Fault Frequency: 30
Reset counter: 241
Mileage: 136560 km
Time Indication: 0
Date: 2017.11.03
Time: 08:44:17
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000042080
Coding: 0010111
VCID: 1E6523139CB8F5C77A9-804A
Subsystem 1 - Part No: 8K0 907 410 B
Component: HOMELINK H01 0010
Subsystem 2 - Serial number: 1770884T2YS401
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000922
Shop #: WSC 35621 000 1048576
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0060
Revision: 00000001 Serial number:
Coding: 0000018
Shop #: WSC 42041 000 1048576
VCID: 698F40CF1576C27FDFB-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH02 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 542
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 352A.0A7664984
Coding: 0000002
Address 5C: Lane Maintain. Labels: None
Part No SW: 4E0 910 217 C HW: 4E0 907 217 C
Component: J759 LDW H07 0070
Revision: 00H07018 Serial number: 800209B2500005
Coding: 0001104
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000007767
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2536475998
Coding: 344530393135313035412056413032353336343735393938
Shop #: WSC 45453 001 1048576
2 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 135582 km
Time Indication: 0
Date: 2017.10.09
Time: 10:44:20
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 135582 km
Time Indication: 0
Date: 2017.10.09
Time: 10:50:46
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900061924
Coding: 0232125
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 143
Reset counter: 235
Mileage: 137035 km
Time Indication: 0
Date: 2017.12.26
Time: 10:33:25
Freeze Frame:
(no units): 0.0
Temperature: -5.0°C
Error Code: 8
Pressure: 2.37 bar
Pressure: 2.37 bar
Pressure: 2.30 bar
Pressure: 2.35 bar
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000904030164
Shop #: WSC 12336 024 394758
VCID: 3431E1BB02344F97BCD-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J9Z10BR
Coding: 1120503
VCID: 5CE1691BCA24A7D754D-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 D HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0050
Revision: 00H12000 Serial number: 11020931300189
Coding: 0221208
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005087332
Coding: 0010900
VCID: 280905CBCEFC3B77005-807C
End----(Elapsed Time: 02:34, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
Ross-Tech: Home
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 137242 km
Time Indication: 0
Date: 2018.02.02
Time: 17:36:48
Freeze Frame:
RPM: 689 /min
Load: 43.1 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 1.0°C
Voltage: 13.462 V
000770 - Cylinder 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 137242 km
Time Indication: 0
Date: 2018.02.02
Time: 17:36:48
Freeze Frame:
RPM: 689 /min
Load: 43.1 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 1.0°C
Voltage: 13.462 V
Coding: 0000002
Coding: 0007597
Coding: 0410624
Component: ELV XXXX
3 Faults Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 214
Mileage: 136544 km
Time Indication: 0
Date: 2017.10.27
Time: 14:23:02
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 233
Mileage: 137024 km
Time Indication: 0
Date: 2017.12.26
Time: 10:32:02
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 207
Mileage: 137040 km
Time Indication: 0
Date: 2018.01.27
Time: 20:28:12
Coding: 4071648
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 211
Mileage: 120568 km
Time Indication: 0
Date: 2016.12.02
Time: 19:20:26
Coding: 0000003
Coding: 0102737
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 250
Mileage: 130781 km
Time Indication: 0
Date: 2017.06.20
Time: 06:29:45
Freeze Frame:
Voltage: 13.30 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 51
Reset counter: 226
Mileage: 136899 km
Time Indication: 0
Date: 2017.11.30
Time: 22:53:50
Freeze Frame:
Voltage: 14.20 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 241
Mileage: 137055 km
Time Indication: 0
Date: 2018.01.31
Time: 20:14:59
Freeze Frame:
Voltage: 13.70 V
Temperature: 16.0°C
(no units): 64.0
(no units): 66.0
Temperature: 2.0°C
Coding: 0133123
Coding: 00000036
Shop #: WSC 02313
Coding: 00150573
Shop #: WSC 02313
Revision: 00000000
Coding: 020000
Coding: 0000100
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 28
Mileage: 133504 km
Time Indication: 0
Date: 2017.08.25
Time: 11:01:06
Coding: 0011218
Coding: 0532707
Coding: 0032351
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 247
Mileage: 137491 km
Time Indication: 0
Date: 2018.02.12
Time: 16:35:11
Coding: 0048283
Coding: 0000000
Coding: 0015510
Coding: 4071658
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 226
Mileage: 137028 km
Time Indication: 0
Date: 2017.12.04
Time: 12:25:24
Coding: 0003477
Coding: 0000008
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 235
Mileage: 137232 km
Time Indication: 0
Date: 2018.02.02
Time: 17:40:30
Coding: 0048686
Coding: 0000026
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 30
Reset counter: 241
Mileage: 136560 km
Time Indication: 0
Date: 2017.11.03
Time: 08:44:17
Coding: 0010111
Coding: 0032364
Revision: --H03---
Coding: 0000922
Coding: 0000018
Coding: 0000002
Coding: 0001104
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 135582 km
Time Indication: 0
Date: 2017.10.09
Time: 10:44:20
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 135582 km
Time Indication: 0
Date: 2017.10.09
Time: 10:50:46
Coding: 0032364
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Reset counter: 235
Mileage: 137035 km
Time Indication: 0
Date: 2017.12.26
Time: 10:33:25
Freeze Frame:
(no units): 0.0
Temperature: -5.0°C
Error Code: 8
Pressure: 2.37 bar
Pressure: 2.37 bar
Pressure: 2.30 bar
Pressure: 2.35 bar
Coding: 1120503
Coding: 0032364
Coding: 0221208
Coding: 0010900
Ross Tech used to offer ten diagnostic scan reads for about $150.00
Sorry, but I don't have time to read through a hundred or so codes/faults.
As so many posts here indicate: Clear all codes (each module manually) and drive the car for awhile. Look for reappearing codes and read them slowly. Act on each one individually. The ones of yours I glanced at seem to be related to a discharged battery.
Except for your engine module and some intermittent errors, here is my interpretation of your errors (but please use it at your own risk!):
1) The keyless sensor from your rear right door doesn't work anymore - you probably need to replace the door handle.
2) Check if your lumbar height/massage from your front passenger seat is still working. A plastic part may be broken or you may have a sensor malfunction. This may be due to a loose connector. In order to check it, you have to remove the seat back cover (maybe even remove the seat).
3) A switch from the driver's seat may have an imperfect contact.
4) Both of your rear right footwell heaters (located on the floor, right under the front seats) are burned out. You need to replace them. As they are expensive, many people choose to leave them as they are, but the errors will remain until the heaters are replaced with new ones.
5) The defroster flap motors may be tired; it shows 'intermittent', so that means it gives signs of malfunction from time to time. You should do a step-by-step ('sequential') self-test in the 08 - HVAC module and listen carefully when the test reaches to that motor, to see if you can hear unusual noises or if you hear movement noises at all. Due to its location, if you will consider replacing it, I don't advise you to do that on your own - you should seek a qualified Audi technician for that.
6) Your Onstar digital radio may be improperly coded. I can't help you here since I don't have Onstar module.
7) Your steering wheel vibration motor is getting tired.
8) Try to lower completely the window from the driver's door, and then lift it completely. Then clear the error in module 42 and see if it is still present after that.
9) The front right (bass) speaker is getting tired or has an imperfect contact. You may leave it as it is, but the fault frequency is rather high so you should consider replacing. But if it doesn't bother you (e.g. if the fault is not noticeable in real case scenario), then you may leave it as it is, until it degrades further.
10) The errors in address 61 (Battery Regulator) are rather information messages indicating that on the mentioned date, the battery was depleting and the car activated some shut-off stages (1 and 2), when some equipment is turned off so the car can save power to be able to start the engine. These are the lower stages, and they may have been triggered simply by working on the car with the ignition on (and the engine off), or by listening to music with the engine off.
11) Your TPMS controller is either malfunctioning or it has an imperfect contact, but either way, the fault frequency is very high (is it still working?) and you should consider replacing.
But before you start spending money and replacing anything, you should seek a second opinion, especially from someone who can see the car. Often an 'intermittent' error is caused by an imperfect/corroded contact.
Will check it. Thanks.
The lumbar doesn't work but that's something way down on the list at this time. Thanks.
Will check it further. Thanks.
Not a big priority as I don't ride with too many people riding in the back. Will look into it eventually. Thanks.
I have heard a noise the last time I drove a few days ago. Nothing major sounding but the noise of the defroster making it's change from a temperature adjustment I made. Thanks.
Will have to dive into this more. Thanks.
Will look more into it. Thanks.
Will do. Thanks.
Gotcha! A new battery was installed prior to purchase. Thanks.
It's still working. There was one tire that threw the low pressure message but now all tires have been inflated properly. Thanks.
Will do. Thanks.
While you're at it, I'd verify your battery is still in good shape.
That's an impressive list, Basenco !
You don't need to fix everything listed, fix the ones are actually working, the scan will remove the related non broken ones. If you try to fix everything on the list, you will end up breaking things that are not broken. You'll be much better putting the VCDS in the bag, fix the car just like your MBZ, you'll be saving money and unnecessary aggravation. I only fixed broken things that I can verify, never what VCDS tells me because the Audi Software engineers aren't so good in problems isolation reporting. The old fashioned way with brains is always the way to keep A8L in great shape for many years to come.
Cheers,
Louis
Cheers,
Louis
