When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
So I had the front end all apart to replace a cracked carrier and do some other maintenance work. I finally got everything done, but while putting things back together I ended up with extra parts and I hate extra parts!! I have two black plastic "covers" that go somewhere on the front end/hood/radiator/bumper. I have spent an hour trying every spot I could think of and I can not find where these things go. If anyone has an idea of what these are and where the go I would greatly appreciate it. I found the parts diagrams for them but the description was less than helpful. Parts are pictured below.
Part numbers are 4E2823772B (right side) and 4E1823771B (left side). They are listed as a "Joint Cover" and show up in the hood parts diagram. ebay calls it a "Bonnet Release Cable Cover Trim". Any help in figuring out this puzzle would be appreciated.
Don't have my car here, but up along the side seams where the inner fender meets the sheet metal fender you see? That is, just below the side of the hood/bonnet where the bolts hold down the fender. The hood cable routes through there, which is probably the parts diagram reference. It's been a while, but they might be as far back as almost the hood hinges near base of A pillar. In any case somewhere along those fender seams IIRC.
Those are air directors for the cooling system Go on side of radiator between radiator and bumper. longer ones on bottom and the shorter ones, those, ones on top.
I definitely think you are on to something as I remember them going somewhere on or near the radiator. However for the life of me I still can't figure out where! I only have two covers - a right and a left. The pictures above are multiples of the same item. If anyone has a picture/diagram/better idea of where they go please let me know.
I don't know. Your last pic shows an air intake on the right, so looks like your V10 has a bit different parts than my 4.2. It looks pretty good overall, based on that I just put mine back together last night so it is fresh in my memory. I take pictures as I disassemble so I can remember any goofy details that go out of my short term memory. Those little fin parts you first posted don't look familiar to me now that I look closely at them. You need someone who has close familiarity like me who also has the V10.
In your first pic they sit on top of the air intake guide - look on the sides of the air intake deflectors - there should be some notches or grooves where the plastic pieces just kind of sits/snaps into place
