In need of help, fast, please!!!
I own an 05 A8L with the dension 500 installed for about a year now,
lately i have many issues with the MMI, many times i will get into the car and the mmi will not work at all (no nav, music, or cruise control) if i press any of the buttons on the right of the **** wheel the screen will go up i will see the mmi logo and then... nothing, the screen will stay up with a black screen, sometimes after awhile it will start to work again like nothing happened.
Second to that in the past week even when the mmi works none of my speakers works beside the left front twitter.
I'm sorry for the long description but please, i need help my car is outside the warranty period
Ian,
Los Angeles, CA
Ian,
Los Angeles, CA
actually it found those codes:
Friday,17,April,2009,17:23:03:57719
VCDS Version: Release 805.3
Address 47: Sound System
Control Module Part Number: 4E0 910 223 K
Component and/or Version: DSP-Amp.-High H13 0440
Software Coding: 0000000
Work Shop Code: WSC 00000
3 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 235
Mileage: 87336 km
Time Indication: 0
Date: 2009.04.13
Time: 12:01:19
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 87657 km
Time Indication: 0
Date: 2009.04.16
Time: 13:06:48
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 87421 km
Time Indication: 0
Date: 2009.04.14
Time: 15:22:36
any ideas for what i should do???
3 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 235
Mileage: 87336 km
Time Indication: 0
Date: 2009.04.13
Time: 12:01:19
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 87657 km
Time Indication: 0
Date: 2009.04.16
Time: 13:06:48
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 87421 km
Time Indication: 0
Date: 2009.04.14
Time: 15:22:36
Cat Herder
well, since the component protection seems activated, I would suggest the following:
1. make sure none of the cables are loose going to the dension.
2. update your dension to the latest firmware.
3. bypass the dension and see if the problem persists.
and i don't know if it's related but i also get this one:
Friday,17,April,2009,18:21:09:57719
Address 0F: Digital Radio
Control Module Part Number: 4E0 910 593 D
Component and/or Version: SDAR SIRIUS H04 0670
Software Coding:
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 250
Mileage: 87932 km
Time Indication: 0
Date: 2009.04.17
Time: 17:25:31
(i'm not subscribed to sat radio)
Software Coding:
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 250
Mileage: 87932 km
Time Indication: 0
Date: 2009.04.17
Time: 17:25:31
Cat Herder
then it's a trip to the dealer for you...component protection has to be removed by the dealer.
Why it kicked in is hard to say. it's possible the amp module is defective, but not sure. I know some amps have had to be replaced in the past.
you didn't try to do an MMI update, did you? this usually happens during one of those if you start from too far back and try to skip...
