Need help on removing rear seat back
I've finally decided to do something about the humongous headrests in the rear, which I think present a real safety issue. I found a custom upholstery shop willing to cut them down to a more reasonable size.
Problem is, they can't be removed except by first taking out (or tilting forward) the rear seat back. And it's not obvious how to do that. I took out the seat bottom and found four bolts (2 on each side) holding the bottom of the seat back in place. But even after removing those, the back still wouldn't budge. Does anybody here know the trick? Are there some hidden bolts somewhere? Is it necessary to remove the trunk liner in order to access them?
Any help would be greatly appreciated. TIA.
<img src="http://www.audipages.com/images/d3backseat1.gif">
Rear seat backrest, removing and installing
1 - Center mounting (4x)
2 - Center head restraint
3 - Rear seat backrest
Removing
- Remove rear bench seat Page 72-74 .
- Detach side airbag connectors -4- (2x) Fig. 1 .
- With seat heating: Detach seat heating connectors - 5- (2x).
- Unscrew bolts -6- (2x).
- Push center head restraint -2- upward.
- Fold center armrest -7- down.
- Unscrew nuts -8- (2x).
- Push rear seat backrest -3- upward out of center mountings -1- (4x) and pull rear seat backrest -3- out from front.
Installing
- Engage rear seat backrest -3- in center mounting -1- (4x).
- Continue installing rear seat backrest -3- in reverse order to removal.
4 - Side airbag connector
5 - Seat heating connector
6 - Bolts (2x)
7 - Center armrest
8 - Nuts (2x)
Removing
Installing
6 - Bolts (2x)
7 - Center armrest
8 - Nuts (2x)
bilbo6209
10
09-04-2015 04:07 PM
OSUNick
NorCal Discussion
09-02-2015 08:35 PM
stormchaser1967
09-02-2015 12:47 PM
