NEED HELP ON VAG-COM FAULT CODE
Hello i have a 2004 A8 4.2 D3 couple of months ago my MMI started acting up sometimes at startup the screen would not fold out and the tel.navi.car.... buttons would not light up. This used to happen only couple times a week but not it happens couple times a day and its annoying. So i decided to scan it with my vag com and this is what i got. I m a very noobist user when it comes to vag com so any help is appreciated thanks in advance.
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 0200503B110F58
Coding: FCFE7BDD1B2304
Shop #: WSC 02313 785 00200
2 Faults Found:
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 250
Mileage: 127438 km
Time Indication: 0
Date: 2012.01.24
Time: 08:06:36
00463 - Control Module for Digital Sound Package (J525)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136781 km
Time Indication: 0
Date: 2012.11.26
Time: 16:17:07
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 250
Mileage: 127438 km
Time Indication: 0
Date: 2012.01.24
Time: 08:06:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136781 km
Time Indication: 0
Date: 2012.11.26
Time: 16:17:07
The optical databus goes from the k-box in the left of the trunk to behind the glovebox in the front, where it connects to the screen control module, can-gateway, cd-changer, ami-box if you have one, and a couple other modules connected to the mmi system. The modules are where you should start to look for a loose connector, another possibility is a broken optical cable.
carbonLORD
11-08-2004 06:11 AM
AcesFull
08-02-2004 02:00 PM
